vandy1981
We live in Nashville, TN, and use our travel trailer on some hunting land in Kentucky. My dog and I did a test run on Saturday to scope out the charging infrastructure and efficiency data to make sure there are no surprises for hunting season. Overall, I was pleased with the towing capability but look forward to the day when there are more trailer-friendly charging stations.
The dimensions of the trailer (Micro Minnie 2100 BH) are 7' W x 22' L x 11' H and the weight is 4100 pounds.
Key observations:
-Overall efficiency was 1.1 mi/kwh over 330 miles. I purposely planted myself behind slower-moving semis in the right lane to maximize efficiency
-I spend $44 on charging and would have spent around $140 with our old gas truck. I spent 2.5 hours charging at fast chargers. My time is more valuable than that, but it's all about the journey and not the destination.
-The truck towed so confidently that I occasionally forgot I was even pulling the trailer. I realize it's a smallish trailer, but I never had this sensation with the Ram 1500 Hemi eTorque that we previously used to tow this trailer
-The trailer backup assist was brilliant when it was working, but it kept throwing errors and disengaging. I'm using the sticker on the trailer tongue and will try relocating the sticker to see if that helps. Otherwise I'll need to look into installing the yaw sensor
-It's unforgiveable that there is no built-in display of kW in the truck or on the app. Other manufacturers do this much better and it's helpful to know if there are any throttling issues with the charger
-Only 1 of 8 EA chargers were broken between the two locations I visited. There were always at least 2 unoccupied but functional chargers at all 3 charging stops.
-Plug and charge was flawless. It's so good that I don't mind paying extra to use the service vs an EA plus subscription through the app.
-Both Electrify America stations I used had the potential to accommodate a vehicle pulling a trailer without blocking chargers. At one location it was only possible if there weren't cars parked in adjacent ICE spots. At the other location, they placed a cart corral directly adjacent to the charger which made it very difficult to maneuver a trailer. I was lucky because I only had to drop the trailer once out of the 3 times I used Electrify America on the trip.
-Pet mode needs to happen ASAP. There is currently no way to see if the vehicle is running unless you start the vehicle through the app
-When you enter a location into the Ford navigation system you get an estimated distance that changes when you actually start navigating. I think the initial value is "as the crow flies" because it's always significantly lower than the actual distance. I was fooled on one of the legs and unplugged too early because the I was going by the initial distance.
-ABRP (using live OBD data) seems to be more accurate than the Ford Navigation in regards to consumption estimates. The Ford system was much more pessimistic than ABRP even though it should have logged hundreds of miles with the trailer profile by now.
-ABRP is supposed to use live weather data in its calculations, but it's really important to be aware of windspeed and direction while towing a trailer. It makes a huge difference with efficiency and may drastically affect your routing/charging strategy.
Trip Data:
Nashville, TN to Clarksville, TN
1.06mi/kwh, mostly between 65-70 mph
Clarksville Electrify America Charger-53% to 91% (50 kWh) over 42 minutes. 3 of 4 chargers were working. I was able to keep the trailer connected while charging. I did not block charging spots, but did block several ICE spots.
Clarksville, TN to Rural KY Town
1.06 mi/kwh, mostly between 55 and 65 mph
Level 2 charging in Rural KY town- 33% to 40% (10kWh). I would have been able to skip this charging session and the Paducah charging station if I had access to a nearby Tesla Supercharger station.
Rural KY Town to Paducah, KY
1.2 mi/kwh, mostly 50-55 mph
Paducah Electrify America Charger-6% to 70% (85 kW) over 49 minutes. All chargers were working. I was able to charge with the trailer connected but had to block one charger because of a poorly placed cart corral. There was an empty, functional CCS/CHAdeMO station during my entire session, otherwise I would have moved.
Paducah, KY to Clarksville, TN
1.08 mi/kwh, mostly 60-65 mph
Clarksville Electrify America Charger-2% to 66% (85 kWh) over 43 minutes. I had to drop the trailer to charge because several cars were parked in ICE spots.
Clarksville, TN to Nashville, TN
.96 mi/kwh, mostly 65-70 mph
Key observations:
Trip Data:
