Activating Trailer Brake Control Module
Azgunguy
Michael
Northern Arizona
2023 Lightning Pro and 2012 Expedition Fleet
I have a '23 Pro ER with Max Tow (no tow tech). It came from the factory with the trailer brake control module installed under the dash. I purchased the proper dash controller switch that fits where the coin slot goes and installed it. I have gone into forscan and turned on every single trailer brake module that i could find. However i only did it where you can change it from "disabled" to "enabled". I do not know the values to change for the "AS BUILT Format". Im still going through livinitup's spreadsheet to figure it out, but if anyone has any insight that would be greatly appreciated.
Zaptor
2022 Lightning Lariat ER 2023 Lightning XLT ER 2025 MME GT RALLY 2021 Chebby Bol
.......... Trophy husband
Following so I can do the same on wife's XLT
-Zap
62F1004x4
Norman, OK
1962 F100 2023 F150 Lightning SR
Maintenance
I am thinking that the black box under the dash is a ‘dummy’ connector. This is what I did to get the brake controller working and posted on another thread.
This worked for this truck, may be different for your truck options, proceed at your own risk.
Ford part number ML3 Z*19H332*F $230 which included both the black module under the dash and a the switch controller that replaced the coin holder. Everything plugged in without wiring modifications.
Ford F-150 Lightning Activating Trailer Brake Control Module 1717940117898-jj
See this post for further information
https://www.f150lightningforum.com/...rd-in-dash-brake-controller.13908/post-368931
TomB985
Isanti, MN
2022 Lightning XLT ER
I did the same, but you only bought half the controller. Ford sells the kit through their accessory store. LINK.
I bought and installed the kit last December and was able to activate it through Forscan. I don’t remember the exact switches I flipped, but they were all in the instrument cluster module. The ones I found in the trailer brake menu were all enabled, so I just needed to tell the IPC that it could talk to the brake controller.
No, it’s not a dummy connector. I pulled up the wiring diagrams, and the trailer lighting circuits go through that box. Unplug the box and you’ll get an error code and stuff that doesn’t work. I don’t know all that’s different with the IBC-capable module, but it’s needed for the switch to work.
Ford F-150 Lightning Activating Trailer Brake Control Module 1717945384466-8o
Azgunguy
Azgunguy
Michael
Northern Arizona
I appreciate it. That was what I was afraid I’d have to do. It’s a rather dumb situation if you ask me. Thanks again.
cal
Cal
Battle Ground WA
Does your controller keep the gain setting after you disconnect. Mine (2022 Lariat, tow package) seems to forget I set it to 5 last tow. I seem to have to reset every trailer reconnection.
TomB985
Isanti, MN
Mine does, and I think it's tied to the trailer I have selected at the time from the towing menu.
cal
Cal
Battle Ground WA
Thanks I only have one trailer profile loaded. But it doesn’t come back when selected.
