Adding Lane Centering without ACC possible?
Nftypjs
Dylan
Hawaii
f-150 lightning pro
I have a 2023 Pro with tow packages. Have successfully changed various things using forscan (doorpad install, bed light install, anti-glare headlights, rain sensor install). The truck already has the active lane keep assist function (corrects after it crosses the lines). I know that the Lane Centering feature is turned on when you add the Adaptive Cruise Control module/harness/forscan updates, but I'm curious if some of those forscan updates necessary for the ACC install are specific to the LC, and can be done to add LC without the full addition of the ACC system. It's my understanding that the forward facing hardware that's presently used for LKA is the same as what's used for LC. If anyone can look into this more I'd be happy to compare forscan info on the differences between models, etc. Or if anyone has knowledge of what it's called in the menus of forscan so that I can experiment on changing parameters to hopefully get the LC option to pop up on SYNC at least. Much appreciated in advance.
Blochead21
PA
Black 22 XLT 311pkg
It’s not possible. ACC is needed for Lane Centering.
Blochead21
PA
Black 22 XLT 311pkg
Sorry meant lane centering. I edited the post above.
Silenze
Wi
If you play around with the settings you can change it from vibrate only to auto steer back into the lane.
These are two different functions, and use two different 'methods' to accomplish the end goal. I wish it were as easy as you suggest, although then Ford would just have it programmed in already. The RADAR unit is required.
I will say, also, that this is not just a 'Ford' thing - it is most every manufacturer. They have one expense to add LKA(Lane Keeping Assist - Audible Alert or Steering) to manage a safer drive if drifting near/over lines, and ANOTHER expense, equipment, to add LC(Lane Centering) to 'keep' the vehicle within the lines.
My wife's new KIA EV9, and even her previous Sorento PHEV, has BOTH, and they are INDEPENDENT of each other. One thing, though, their systems allow you to have LC active even WITHOUT Cruise Control on, while it seems Ford's LC is only active when in Cruise. Correct me if I'm wrong... on my PRO's 'added' AC/LC, it only provides LC when in Cruise.
Ventorum94
FL
Mechanical Engineer
You’re referring to “Lane Keeping,” not “Lane Centering.” The former is the basic older technology, that vibrates if you drift, and can be set to intervene to keep you in your lane (hence Lane “Keeping”), but the result is ping-ponging from left to right within your lane; all Lightnings have it, regardless of trim level. Lane “Centering” is the upgraded capability, and works as well as Tesla Autosteer (part of basic Tesla Autopilot). Lane Centering is perhaps best described as “Blue Cruise that isn’t handsfree.” It requires ACC, and is only offered by Ford on Lightning XLT 312A package, Flash, Lariat, and Platinum, not Pro or base XLT.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Found this thread while looking for answers to the question, "Why is the lane keeping on my new 2024 XLT almost completely (and dangerously) useless when our 2021 Mach-E's lane keeping works well?" I think I've fallen prey to poorly calibrated expectations.
When the lane keeping button of the XLT is pressed, the display says "Lane keeping system on", but the truck will happily drift off a well marked road without so much as a chirp...then after a few seconds, assuming I haven't allowed the truck to run into a tree, it tells me I might be too tired and need a break. This suggests it knows we've gone out of our lane but not bothered to say or do anything about it! Sometimes on a straight bit of road it works OK to apply corrections, perhaps to lull the driver into a false sense of security?
BTW, this is with lane keeping assist and warning enabled in the menus.
From previous posts, it seems that the XLT without ACC has a stripped down version of lane keeping. Not sure why they bother with it, really, as it seemingly can't be relied on in even a slight curve...and I'm not going to trust it on any road as it is.
If I find a great deal on an ML3Z-9E731-G RADAR for ACC, it might be a good experiment to install it, do the ForScan hacks, and see how much changes. Thanks to all you previous posters for making the distinction between "assist" and "centering" much more clear than the manual does.
Mach Turtle
Central California
Bum
Thanks, @Firn, for describing the difference in a clear way as the marketing division of Sirius Cybernetics FoMoCo ought to have.
