Battery Percentage Dropping at Random
ctuan13
ctuan13
Chuck
Pittsburgh, PA
I just experienced something like this for the first time. I’m on vacation with only level 1 charging. The truck had been charging on level 1 for about 44 hours straight from 54% ish to 93%. I unplugged and went to the grocery store. Ride there was fine. On the 3 - 4 mile ride back the battery percentage started dropping rapidly from 91% to 82% in the span of just a couple miles. It seemed to stabilize at 82% so far. I parked and shut off the truck for now while I unload groceries. Hopefully this was just a BMS calculation error and not some indication of a bad battery module or something. No errors were thrown and no overheating or anything.
First thing I'd try is a 12V reset. Disconnect the negative battery terminal and leave it disconnected for 10 minutes. Reconnect. Unless it's a more serious problem, that should fix any issues!
ctuan13
ctuan13
Chuck
Pittsburgh, PA
2025 Update
I haven't had any major issues with the battery pack since and battery SOH (State of Health) is still sitting at 100%! I'm back at my friends' place in Washington and made it here much faster with much more DC charging and less AC charging.
MountainAlive
Massachusetts, USA
Update on my battery percentage drop. I found a local level 2 charger and used that to charge up to about 95% and everything was fine. There seems to be some kind of software bug when level 1 charging above 90% in my case. The BMS wasn’t able to figure out just what state of charge the battery held until it drove for a while. I drove back from vacation today (~150 miles) and everything was fine.
