Best place to pick up switched +12V for Dash accessories?
Severdog
Craig
Greenville, SC
2022 F150 XLT Sport (ordered)
Trader
Is there a simple tap point in the dash to pick up switched 12V to run a couple of accessories that I plan to mount on the dash?
I don't know the current draw of these items at this time, although probably not significant (couple of androids and a gopro).
If necessary I can pull in a "beefier" supply line and use the switched point to drive a relay...but curious if anyone has already selected a good power tap on a 22.
thanks
AAWhyte
Alex
2022 Lariat 5.0
PM
I used the passenger foot well fuse panel to pull power for my front and rear dash cams. I used fuse taps to make it pretty easy to get power. If I remember correctly I used Fuse #2 for my constant 12v and fuse #4 for the switched ACC power. And there is a nice ground right next to the panel.
Dolio
Ryan
Tacoma Region, Washington
youtu.be
2023 Lightning Lariat ER Max Tow Carbonized Gray
