Can a WDH increase towing capacity (SCrew, Powerboost, Fx4)?
bboy_72
Bob
Denver
F150 Lightning
I have a Powerboost Fx4 Supercrew on order, and I did not add the trailer towing package (or max for that matter) as I did not realize that these packages increased towing capacity from 7,000 pounds to 11,000 pounds (or more). Dumb me, I know. The dealer tells me that, while it is too late to change, if I replace the class IV hitch with a weight distributing hitch, I can tow 11,000 pounds, but I cannot find supporting documentation of this statement. I will likely only ever need that towing capacity very rarely for vacations pulling a travel trailer, but I am curious nonetheless.
Can anyone clarify?
UGADawg96
JAX, FL
302A 157 PB
If you don't have a VIN yet, you can edit your order. If you plan to tow a TT, I'd recommend adding one of the packages.
UGADawg96
JAX, FL
302A 157 PB
And you can't replace the hitch with a WDH. A WDH hitch works with the factory hitch.
bboy_72
Bob
Denver
F150 Lightning
VIN already created. Bummer
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Can anyone clarify?
Your dealer is a moron. First, the Class IV hitch refers to the receiver. The weigh distributing hitch is the thing that slides into the receiver. Two different pieces of equipment and one does not “replace” the other. They work together. Second, weight distributing hitches do not increase maximum tow ratings. Although manufacturers frequently specify two tow ratings for their vehicles—a reduced rating for a weight carrying hitch (often about 5,000 for light duty vehicles) and a maximum rating for towing with appropriate equipment (like a WDH) the 7,000 pound rating for the F-150 without a tow package is the maximum for that vehicle.
I would recommend not asking this dealer for towing advice.
bboy_72
Bob
Denver
F150 Lightning
Well explained. Thank you.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Personally, I think the 7,000lb rating for vehicles without the Tow or Max Tow package is bogus. Looking at what either gets you compared to the Tow Tech on vehicles that come with the class IV receiver is minimal at best, especially on Powerboost trucks.
If you get pulled over, all that is going to matter is the ratings on the sticker on the door jamb and the weight of your truck/cargo/trailer. I looked over both the stickers on my truck and there's nothing listing maximum trailer weight.
JEB
Northern Illinois
Well, if your only worry were the roving trooper looking to fill a ticket quota on a “bogus” technicality, I’d agree with you that towing overweight is probably not much of a concern. However, if you were to come to your dealer with a bent frame or damaged springs and demanded warranty coverage, Ford would know the weight rating. If you were to get into an accident, your insurance company would know the weight rating. And if you killed someone in that accident I promise you the plaintiff’s lawyer would know the weight rating. Not worth the risk to me.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
The components that make up the various towing options are all available from Ford and/or aftermarket. So I would argue that you can equip your truck with more towing capacity than your Payload Capacity will support.
imnuts
Dirty Jerz
Facilities Engineer
Just curious, how would the frame be bent or springs damaged if you were within your vehicle payload? Pretty sure if you were in an accident, the insurance company is also going to care more about the weight ratings on the stickers plus actual vehicle + load weight than whatever Ford put as an arbitrary trailer tow rating as well.
I'm also very interested to know what component(s) are added to the truck with the Tow Package allow you to tow a trailer that is 4-5000lbs heavier? From all the information I can find in Ford's documentation and posted here, there's nothing added that would change a towing rating. The fact that they don't put a GCWR on the stickers on the truck makes it even more arbitrary.
jj4567
United States
2022 F-150
You aren’t alone.
Many of us want to know: What's in the Trailer Tow package (53A) that isn't in the Tow Technology package (17T) . . . or did many of us just get ripped off?
https://www.f150gen14.com/forum/thr...tech-17t-vs-trailer-tow-53a.7512/#post-135093
