Central TX camping?!
thedadlegend
Stephen
TX
Smoked Quartz Lariat ER
Looking for recommendations on state parks or camping spots in general that offer 30 or 50a hookups.
Was looking at Garner but it’s full up, sadly.
So where have you been Site recommendations? Time of year?
Amps
Mid-Atlantic
Bolt
Beware, 30A often means a 120V 30A TT-30 receptacle. The truck will only Level 1 charge at 12A maximum. It's fine if you're going to be hooked up there for a few days. (50% charge in about two days)
thedadlegend
thedadlegend
Stephen
TX
yep, plan to be there for two nights
Will I need a whole new charger or just an adapter to the ford mobile charger?
they had 50 amp spots but i didn’t want to be surrounded by RVs
Pod
2023 AMB Lightning XLT SR
50A makes life so much easier though. I was of the same mind ( away from RV ) but the 50A that can plug direct without an adapter is so much better time wise.
Amps
Mid-Atlantic
Bolt
First maybe make sure what type of 30A receptacle is available. Is it 120V or 240V?
You'd need an adapter to use a TT-30 receptacle. My point was that having 30A@120V available is of no real benefit for charging. Plug the Ford Mobile into a standard 120V 15A or 20A receptacle that is almost certain to be right there on the pedestal at the campsite. And, realize that it will be real slow.
Here's what a TT-30P to 5-20R adapter would look like. The clear end is three standard household outlets. Again, you won't need it if you have access to a standard household outlet:
https://www.amazon.com/Rophor-Adapter-Generator-TT-30P-Lighted/dp/B09V4T6R66/
thedadlegend
thedadlegend
Stephen
TX
Nice - I'll probably get an adapter. For some reason I thought there was a fire/safety issue with trying to use the Ford Mobile on the TT-30... I will probably get a full charge, then drive 90 miles to the site, so I shouldn't need a 50amp except for peace of mind.
thedadlegend
thedadlegend
Stephen
TX
Actually, will this work as it says input voltage must be 240 (edit - I was looking at a splitvolt charger not this adapter, oops)
Amps
Mid-Atlantic
Bolt
If you’re using the Ford Mobile, you’ll need to change out the removable 240V plug on the body of the unit. There should have been two with the unit. Put the 120V one with the standard house plug firmly into the unit. Plug it in and try charging at home before you travel to get an idea. You should be fine driving 90 miles with no adapter if you learn how to use the Mobile on standard household receptacles.
ullearn
Ullearn
Viper / Tesla
Maybe make the RV parking spot the basecamp and do some hike in camping in the backcountry.
Favorites are always:
- Garner
- Inks Lake
- Enchanted Rock*
- some of the "state natural areas" but they usually don't have hookups
- you can also checkout hipcamp
Texas Dan
Daniel
I highly recommend Palo Duro Canyon State Park. The scenery is breathtaking and they have NEMA 14-50 50 amp outlets. If you’re into history, there was a famous Indian battle in the canyon during the Red River War.
thedadlegend
thedadlegend
Stephen
TX
I’ve heard this!! I think I will plan for it. When’s a good time to go?
