bc1
- Oct 25, 2025
- McPherson, KS
- 2025 Ford f150 Lightning Flash
So if I plug in every night and can adjust my charge point, what would be the optimal rate and still get a recharge in 8 to 10 hours? I know you might say to trickle charge it or something but I can set my chargepoint hardwired station with a lower breaker/amperage rate than it currently has. I already have an ER battery and I've got it set for the 60 amp breaker which is the max it will put out which I believe is 48 kwh per hour.
Also does how far you regularly/daily run down the battery and recharge it back up (such as down to 0 to 30% and back up to 80 to 100%) compared to (such as down to 60 to 90% and back up to 80 to 100%) affect longevity of the battery pack? Thanks.
