Converting a truck to CCS2
ZeusDriver
East Coast, USA
2022 Lightning
Don´t think changing the cable only will help. Most probably a different inverter/charger is required as well.
I don't know, but am inclined to agree. I've read (but on the internet, where anything goes) that the chargers are different, which makes some degree of sense, given three phase rectification would require, among other things more diodes. Ford can be agressive in cost accounting, and there are arguments to made both ways for having one adaptable unit vs two cheaper, but non-adaptable units. I would not be surprised, if in the interests of keeping the US build cost as low as possible, a cheaper charger is used here.
From the title of the post I assume he wants to convert a CCS1 truck to CCS2.
So that is only needed for DC charging and there are adapters to do that.
Now, if he has Lightning with the CCS1 port and want to charge AC using the European Starndard (which is NOT J1772) then there is an adapter for that as well.
Adapter for type 2 EVSE to J1772 vehicle:
https://evseadapters.com/products/european-to-us-type-2-iec-mennekes-to-type-1-j1772-ev-adapter
Now if he wants to charge L2 at home with the CCS1 port then he can use any US made J1772 EVSE wired as mentioned to get 220V (one hot and the neutral on a three-phase supply system).
I am an electrical engineer, and I am basing this only on what I have read about the EV standards and electrical standards in the Netherlands (where some of my distant ancestors came from BTW).
So he should consult a local electrician to be sure.
And now for the disclaimer:
I am an electrical engineer but not a licensed electrician.
The information provided in this post is provided for information purposes only and does not constitute any endorsement or recommendation. No warranty, expressed or implied, is made regarding the accuracy, adequacy, completeness, legality, reliability, or usefulness of any information found in this post. It is your responsibility to verify and investigate this information.
