Driving with gloves
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
It doesn't. Steering wheel heat is either on or off. Seat heating has three levels.
It doesn't as a standard user setting, you can adjust it in Forscan.
roddiaz1
Rod
Pittsburgh
I believe the steering wheel settings the O.P. is referring to is "On"and "Off".
After all, those are settings.
Jseis
Washington
News to me that steering wheel heat has settings...
Haha. Got me there … Sometimes it gets uncomfortable and I think I should turn run it down. When I actually turn it off.
Heliian
Middle aged Canadian here.
It's not an issue, I rarely get into a cold soaked truck.
They sell touchscreen compatible gloves if need be.
Best bet is to use preheat so you don't need gloves. The heated steering wheel is a cornerstone to winter driving for me now.
MaintGrl
Marsha
El Sobrante, Ca
MaintGrl
Marsha
El Sobrante, Ca
hb.sagen
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
I would also add you can use the voice controls and never have to take your hands off steering wheel.
Announcing, to the entire crew, in a foreign language, that my butt is cold, possibly in three tries, is not my preferred solution :)
I usually drive with some light gloves in winter time, but adjusting temperature or opening my garage door requires me to remove my gloves. Not a great solution in heavy weather, when hands on the steering wheel is a necessity. I Asia they use sausages to enable touch while gloved, but I am not going down that road.
Do every American drive gloveless? Or do Ford sell touch-enabled driving gloves?
Even with bare fingers, I have troubles with touch screens - my fingers are not conductive enough I guess.
Here's what you might want to try:
https://www.harborfreight.com/high-...source=google&hftm_sc=3608&hftm_source=google
I spent like $8 on gloves from amazon that work on touch screens...great purchase. The thumb, index finger and middle finger work on the touch screens...works great.
https://www.amazon.com/dp/B07JYMHWPP?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1&psc=1
Maybe that would help me - my bare fingers have issues with touch screens - I made an aluminum foil thimble for my index finger but have to take it on and off all the time...although it matches my tin foil hat!
