Eco. 2.7kw outlet system flaw?
aaexpert
nh
21 f150 platinum
Started to test the bed outlet and found this... Turn on the Power and Generator mode, shows 2kw available but rests at 200w. The adjustable temp. controlled Wagner Heatgun turns on ok, but doesnt get enough watts to heat up. If I plug in a non-adjust. heatgun it works fine and the dash reads 1kw of power being used. It seems like I may need to put a 2nd 'load' on the trucks outlets to get the full 1k to run the adj. gun ??? Seeing if anybody else has run into this type of scenario yet.
