Sahit
- First Name
- ROBI
- Apr 23, 2025
- KOSOVO/WESTERN BALLKANS /EUROPE
- F150 Lightning 2022 LARIAT
Thanks for the explanation, it makes sense.I am not sure if the BMS recalibrates on it's own over time, or how long that would take.
I have heard that can happen in the ICE F-150's, so maybe it is true in the Lightnings.
But in the mean time, one might have an under-charged battery being drained further by the vehicle while in use and by parasitic draws and the BMS will not detect the real SOC of the battery.
When the battery gets down low enough the DC-DC converter is supposed to activate to charge it. But if the BMS thinks the battery is already charged, it will not trigger the DC-DC converter.
If not calibrated when a new battery is added, it may begin to load-shed thinking the fully charged new battery is the depleted old battery, and that could result in errors like the OP observed.
I think if you look for other threads about resetting the BMS you will find this is the case.
I also want to add that even the original 12V battery holds the charge fine when charged externally, so the battery itself does not seem to be the issue. This makes me think the problem may be elsewhere, possibly software-related. I have not received any software updates since I imported the truck from the USA.
The vehicle was parked normally in my garage in a fully working condition, and the issue appeared suddenly the next morning without any prior warnings or messages. This sudden failure also points more toward a software or BMS-related issue rather than a bad battery.
