Ford bed divider on rails
COrocket
F-150
Has anyone used this setup before? I’m looking to burn some FordPass points and I’m not a huge fan of the regular box link divider, since the area by the tailgate is a bit small. An adjustable divider seems much better in this regard.
The rails are simple enough to order, but it appears to be hard to find the divider portion online either due to discontinuance or popularity.
I was also considering a simple 2x6 board by the wheel well but i don’t see how it would hook into the spray in bedliner on the side by the pro power ports.
Ford F-150 Lightning Ford bed divider on rails IMG_3734
Heliian
It looks like you can order it but lead time is unknown. A little pricey for my tastes @ almost $900 CAD for the rails and divider setup.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), 2023 F150 Lariat ER
I got one of those flip out 'extenders'. I think I've only used it once for an extended bed, but it gives me about a 2' space to put things that won't end up sliding to the cab. It's easy to remove, and I can even stick it at the front or back under the tonneau if I need the entire bed free.
COrocket
F-150
Thanks I think that’s in the running as an alternative since it seems to have a more reasonable amount of storage space
davehu
hot springs, AR
Ford.com shows the divider would ship by Nov 7th. Same for the rails. I'd love to add this but $700! not gonna happen for me.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
I had a bed extenderI loved but I had to remove it because I have a really nice tonneau cover that I like but unfortunately the flip out extenders hit it.
El Duderino
2025 Flash Job 1
Ford F-150 Lightning Ford bed divider on rails FB_IMG_1759612251347
I saved this photo off FB group. DIY option.
