Ford Voice for seat heater and wheel?
Gato Meoow
NY
08 Prius
Is there a voice command for the seat heater or the steering wheel heat? I tapping on the screen isn’t the smoothest and the wheel is ok but voice would be great. Check the manual but no luck.
The Weatherman
South Central KY
Not that I have seen (heard).
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
I can't tell if this is a serious post or not.
TheWoo
Manhattan, KS
Why would this not be serious? Controlling aspects of climate by voice is not uncommon. If you can set the temperature or turn on max defrost with a voice command (I don't know if you can do that second one, btw), why not turn on a heated steering wheel or heated seats?
Gato Meoow
NY
08 Prius
Lmao. Yes it’s serious, the manual says over and over to use voice commands to avoid looking away from the road it seems that is the function I use the most. The ford voice command stuff seems to be pretty useless, I use CarPlay for everything else.
kstype
Kurt
Pennsylvania
Principle Systems Engineer
Unfortunately, they still have a lot of work to do with their voice interface…hopefully as their software matures, they will add these features to the voice capabilities - I believe the technology within the vehicle is in place to support it.
Smokewagun
Bob
N. Illinois
2019 Ford F-150 Lariat 3.0L Stroke
Try turning on “Hello Ford”. I have used it for other settings. I’ll try it today and get back to you. Searching/selecting music from a USB is a best when driving. Screen is locked. Only plays current album. Hello Ford allows me ANY search or play.
The onscreen list just shows examples:
Set temp to low
Set temperature to <60-85>
Change the climate to high
So for you programmers/engineers :) :
{set | change} [the] {temp | temperature | climate} to {low | high | <60-85>}
kstype
Kurt
Pennsylvania
Set temp to low
Yes - climate HVAC they have covered - seats and wheel heat not covered.
