Forscan to upgrade Phone as a Key
First Time Ford
Joe
Smithers BC Canada
2022 Ford Lightning Lariat ER
Self Employed
Does anyone know if I can upgrade my 2022 Lariat ER to enable Phone as a Key using Forscan. Also how can I determine if my truck should have PAAK?
Thanks,
AZT9
Peoria, AZ
I have the same model year and trim. Your truck absolutely is equipped with the correct hardware for PAAK. Took a few SW updates to activated it after taking delivery. So it is possible
Forscan won't do it. You will need FDRS.
Henry Ford
Specifically, the RFA module needs to be updated. When I did it I had to remove the vin from FordPass after the update to get it to work.
