3rd rock
Automotive Technician
Would people REALLY need to install a charger for those? I've had my Lightning since July and have been home charging using the 110v charger that came with the truck, topping off once a week at a DCFC nearby. My commute is 50 miles daily, so it can't QUITE keep up. So for someone with an EREV or PHEV, would they really need a level 2 at home?
And for what it's worth, I got slow rolled by my first electrician and that slowed me down until I moved on to #2. Now I'm close enough to see if there's any good deals for Black Friday.
Your dealer didn't give you a code to order the FCSP? Got my truck in June and it came with free install as well. Ford promise 2.0, check the date to see if you qualify.
Maineiac12
Iowa
you just wait a few more years and see if you have the same opinion. I thought my EREV Cadillac ELR was the best thing ever. Until I found out that small battery in there takes a beating. You chew through its life cycles like no tomorrow. constant engine issues and maintenance due to it not being used. Lack of 3rd party mechanics that will touch it due to its complexity.
I get it, because I felt the same as you. BUT... I will never buy a hybrid or EREV again. Battery tech and infrastructure just keeps on improving. Wasting development and factory funds on ancient/inferior technology while your competitors are doubling down on future technologies will not end well.
My hope for Gen 2 lightning is that in their quest to cheapen it, they make sure it stays a truck. I bought a lightning over its competitors because it's really a truck.
Towing is part of the truck things. I think that’s why they are considering EREV. Even people don’t tow, they want to be able to. It’s my only complaint with my flash. If I only had another 100 miles of towing range it would be perfect.
Altivec
That doesn't change anything I said. I tow a lot with my lightning. 99% of the time, it's well under 100miles so no charging is necessary. A couple of times a year I do take it out long distance. When towing with my gas trucks, I would have to stop for gas more often too, an EREV wouldn't be any different, probably worse because it's going to have a smaller tank. Yes, I'm stuck at a charger for maybe 20 minutes longer than a gas stop a few times a year. How about all the savings in time not having to go to a gas station for the other 99% of the time. All the time savings and costs in maintenance, dealing with fuel stabilizers, and added complexity. I know which one I would choose.
I know for some, they tow long distance a lot. If that were me, I would be getting a gas F150, end of story. If that's all you do, when are you going to gain anything from the EV side of a EREV. Just hauling a heavy battery around for the fun of it.
If you are someone that tows long distance often but stick around the city a lot too where you will be taking advantage of the battery, then expect to chew up its small battery life cycles within the trucks usable life. In other words you will reach a point where you will have to decide to spend big bucks on a battery replacement or write-off the truck. That's where I am at with my ELR with only 50k miles on it.
There might be some niche case use where an EREV would be the best choice but I would not be able to pin point it. Batteries will continue to get better, infrastructure will continue to get better. China already has cars going insane distances with extremely fast charging speeds. Ten years from now, this conversation will be meaningless everywhere except for the US where bad after bad decisions keep getting made.
