Home Integration System, Time of Use, and Non SunRun solar
Perotman
Jason
Rancher
I recently bought an F150 Lightning, and the HIS kit from SunRun. (I don’t think the value is there, btw). I originally made the purchase, thinking I could use the battery in the Lightning for time of use (basically charge it with excess solar, during the day, and then power the house at night, off the Lightning battery), but that feature is apparently still 6-9 month away.
I do have a generator input on my (2) Solis 10kw inverters, which I have running in parallel, for 100amp service, (non-SunRun solar), and I have 10kwh pylon tech batteries attached to each inverter.
I am curious to know if I could wire the HIS backup panel, via (2) 20amp breakers (one for each Solis inverter generator feed), and then set up some sort of triggering system to the transfer switch, that when the solar panels are no longer making power, it would cut power from grid, thereby, tricking the HIS system, into a backup scenario,, that would allow power to flow from the 131kwh battery in my Lightning, to the Pylontech batteries that are designed for time of use functionality.
Danface
Dan
Central Mass
2023 Lightning XLT
Just a thought, a raspberry PI and the Home Automation tool set may do the trick. I
vic7780
Victor
Quantico VA
F-150 Lighting - Atlas Blue, Max Tow, 511a Package
Citizen
Could you talk more about the HIS? I’ve wanted one for a while but haven’t been able to get much info without committing to purchase from SunRun (AEES).
how much did it run you? Equipment and installation? Does it work as advertised?
If this is better to do direct message, let me know
Another point, just from reading other's experiences as I don't have it, it takes upwards of a minute or more for the HIS to kick in. I'm not sure you want your home to completely turn off for a minute every day.
