It Fits!
Dawg7478
Bill Berryman
Athens GA
2023 Ford Maverick
I asked for suggestions a while back about measuring a Lightning to see if it will fit in my garage with shorter than normal doors. Thanks for some good ideas. My salesman went the extra mile with some scenarios, and I concluded we’re OK, but barely. picked up the truck yesterday and…success! Can’t wait to start the EV journey.
Ford F-150 Lightning It Fits! IMG_2914
Ford F-150 Lightning It Fits! IMG_2912
gheron75
Nate
F150 Lightning XLT Standard Battery
Congrats! You have so much room! I have a house built in the 50s, and I didn't think my Lightning would fit in the garage. Turns out, if I'm veeeery, very careful, I can get it in with -- literally-- 1 inch clearance behind and 1 inch clearance in front. Sides are enough to get in and out, but the front/back are tiiiight. :)
JRDM2
J
2025 Lightning Flash
It’s a much bigger truck than I expected but I've never owned a truck. I have plenty of vertical space. It’s a little tight to one side and I have enough room to access the tailgate or trunk, one or the other at any given time, when the overhead door is closed. Also, before this, I kept my vehicles outdoors. Being BEV I wanted it indoors during winter for efficiency and charger access. This is also my first vehicle I got new so I wanted to protect it more.
proprepper
Grayslake, Il
2022 Pro SR
done with work!
Mines tighter than yours. 1/4 inch (front has to kiss the back wall). Glad you fit. Same here last 3 trucks kept outside. This one gets inside when needing home charger.
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
Congrats! And I'm jealous of you being able to park it inside.
garsh
Brad
Pittsburgh
2023 Ford F-150 Lightning Lariat
Similar situation here.
I have about 3" of clearance between the roof and the garage door opener arm. And that was after I sawed off the extra length of metal that extended down further.
I did have to remove the whip antenna to keep it from rubbing against the open garage door.
Ford F-150 Lightning It Fits! 1771790596961-zk
Dino
Dean
Nashville area
23 XLT Lightning, 25 Cadillac Optiq all electric
When I test drove mine, I drove it to my home and pulled it into the garage to make sure it would fit before I purchased it. The salesman was checking to make sure the roof and garage door did not scrape.
