Remind me on Monday. I have a lot of things going on across several forums and I will probably forget.Yes sure it’s 1FTVW1EV4PWG06343
for your information
if I look on the FordPass app it shows the vehicles location exact
thanks
That I am not sure about. I can tell you countless F150 owners have messed up their software and corrupted server back-end data by swapping out APIMs from other vehicles in order to upgrade the touchscreen from 8" to 12". if whatever APIM you buy is not programmed to the proper level it needs to be when you install it, it may cause problems that will break the ability for the vehicle to be update via OTA or FDRS.Ok thanks for all your time and help, do you think I could get a APIM from a uk mach e or Similar sync 4 with Europe maps and use forscan to change the code settings to duplicate my Ford lightning ?
Ok, give me a bit to set it up and I'll message you the details.Ok, can you send me the information to get it programmed for open world maps please ?
"Not completed" means that particular OTA failed for some reason. It does not mean there is a problem. You just have to wait for the OTA to be resent.Thanks for the reply, and thanks for pointing me toward that tread. It has a lot of good info.
I do have the Carperformance TCU, and I got a OTA, but I am now hung up on TCU-25.2.8.5, which is not completed. FordPass works. PAAK works.
I might just have to try the Carperformance APIM, but I was hoping it could be coded instead.
Is there a way to initiate that? It's been like this for about a month already. FordPass website says it's already installed. 25.2.4.9 is the latest I got on 12/23/2025"Not completed" means that particular OTA failed for some reason. It does not mean there is a problem. You just have to wait for the OTA to be resent.
Message me the VIN. I can check the OTA history and we can talk off the forum. But no; you cannot initiate the OTA trigger yourself. You may have gotten the same OTA sent twice and it failed the second time which is why you are seeing that message about not completed.Is there a way to initiate that? It's been like this for about a month already. FordPass website says it's already installed. 25.2.4.9 is the latest I got on 12/23/2025
PS, I don't want to take over the tread from the OP, so let me know if you want me to start a seperate thread about my issues.
