CD4TNF
https://www.motortrend.com/reviews/2022-ford-f150-lightning-lariat-long-term-update-18-verdict
The editor drove it for the past 18 months. Many of the strengths and weaknesses we've shared as owners here are similar options of the article writer.
Strength
  1. Comfort
  2. Performance
  3. F150 things
  4. Cost to charge
Weaknesses
  1. Range. Actual range VS GOM and EPA range
  2. Backup camera
  3. OTA updates
MotorTrend is continuing their long term test of the Lightning and the writer is handing it off to the next editor. Overall great to see a positive review from a mainstream auto reviewer organization.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
What is "GOM" range?
I agree that keeping this truck 95% F-150 and just swapping out the powertrain was brilliant on Ford's part. It kept costs down, kept reliability up, and makes the truck more serviceable and cheaper to insure.
MountainAlive
Massachusetts, USA
Pretty straightforward review. It’s cheaper to run compared to its gas cousin, don’t exceed 70mph if you want long battery range, and it’s great at truck stuff. I don’t understand the rear view camera complaints though. Mine always comes on in reverse. Never had an issue with that. For safety I do feel all these big truck need to automatically display the front camera when you first start the truck and start moving (up to say 7mph). So much can hide below the hood on these things.
CD4TNF
The range number on the front dash is affectionately and aggravatingly called "Guess-O-Meter" because the range is a best guess by the truck. Basically our short hand way of saying to not trust the actual range number displayed.
I usually take 50miles off the GOM range and call that my range.
Or
I'll usually use invertedspear's calculator for my range figure based on the truck's reported efficiency. Much more accurate. I've been safe using this method on my road trips.
https://lightningcalcs.pages.dev/?battery=131
Mike G
N. AL, USA
Or
50 miles! Perzackly! That's also my fudge factor number for the GOM.
Thunderand…
Patrick
2025 Lightning Flash
FireFighter
Guess o meter
WXman
Central Kentucky
www.facebook.com
Ahhh ok. I've had my truck for one month this weekend. It's been on one long trip and lots of commuting around central Kentucky. So far my actual range has been consistently better than the dash display. I can, for example, drive 30 actual miles and only use 24 miles of range.
CerebralPrimate
Kevin
2022 Lightning Lariat
I saw that review and thought it was fair, but then they reviewed their same year F-150 Hybrid and said people should choose it over the Lightning, that it was a better total package. WTF?!?! How?
djwildstar
Guy
Atlanta, GA
Information Security
As a broad generalization, the truck gets the advertised EPA range estimate at about 55 MPH, give or take a bit. If you generally drive slower than that (for example, mostly back-roads or in-town where speeds are 30-45 MPH), then you'll get better range. If you drive faster, you'll get significantly less range: for example, you'll take about a 20% hit at 70 MPH and a 36% hit at 80 MPH.
The "Guess-O-Meter" range estimate is based on recent driving history, so it should get a bit more accurate as your truck learns how and where you usually drive. Be warned, though: this means that the displayed range can be way off if you're doing something different than your usual routine, or if you just got back from a road trip.
The best way to handle this is to set a destination in the on-board navigation: when a destination is set, the truck figures speed limits along the route, elevation change, as well as current traffic and weather into the range estimate. It is usually pretty close, if you drive at the posted speed limits (if you drive over the limit, you'll get less range). I tend t set the destination, and then change my driving speeds so that I arrive with whatever reserve range I'm comfortable with.
RipInPepz
Erik
Ohio
2025 Flash Antimatter Blue - 131kWh ER, 9.6kW PPOB
Its funny because the hybrid is a worse version of the Lightning and the fully ICE truck. Just choose one or the other, not in between!
