Powerboost generator essentials
chill_will
Will
Montgomery, TX
2021 Powerboost F150 Platinum 4x4
I should be receiving my powerboost hopefully by…Halloween like many others :confused: and figured I’d use the extra time to get some essentials.
My question is if y’all could help steer me in the right direction for the best electrical components needed to properly power (partially) my home in the event of power outages?
Does anyone have a setup they have used and loved? Thanks!
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
This is actually a pretty complex subject. I was able to get the truck directly wired to the house without tripping the truck's GFI by not wiring the GROUND (I originally mistakenly said neutral which is completely wrong!) but I am not sure if the is a safe option. Lots of discussion here. I have not seen any postings of anyone else wiring directly to the panel of their house. Would be great to hear from anyone else who has done this.
chill_will
chill_will
Will
Montgomery, TX
This is actually a pretty complex subject. I was able to get the truck directly wired to the house without tripping the truck's GFI by not wiring the neutral but I am not sure if the is a safe option. Lots of discussion here. I have not seen any postings of anyone else wiring directly to the panel of their house. Would be great to hear from anyone else who has done this.
Thanks! Hoping someone who has solved the riddle can comment. I’ll check out that thread as well.
From what I understand, the lightning has the same size generator in the bed (additional 2.4kw in frunk?) and can power a home according to their marketing. I know I can run some extension cords and power strips into the house but would love to see someone who has leveraged that 30A outlet.
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
blueovalguy
NY
2021 Lariat Powerboost
Not being an electrician, The fact that it has 4 120V plugs should allow me to power anything I need for a power outage (furnace, fridge, lights).
Having used the generator feature MANY times already, I will say it uses much more gas than a wheel around generator. Probably close to a 2:1 ratio (haven’t done exact math). So I guess most important tool is: A Full tank of gas!!! I actually fill up whenever I get to 1/2 way mark now simply for the fact of Incase I need power at home.
chill_will
chill_will
Will
Montgomery, TX
That’s what I do now with my stand alone generator — run extension cords into the house and power appliances with a power strip. This gets problematic when, like yesterday, our power goes out right before our 10mo baby’s bath and bedtime. Having to scramble to get cords and power strips hooked up to all the baby stuff.
Talked to my electrician buddy today and he said he can set me up pretty quick. It’ll require some wiring work with the electric main. I’ll post what we end up doing but in talking today, I should be able to power my house (less AC and hot water heater). I won’t be able to test the pro power generator until who knows…
blueovalguy
NY
That’s what I do now with my stand alone generator — run extension cords into the house and power appliances with a power strip. Talked to my electrician buddy today and he said he can set me up pretty quick. It’ll require some wiring work with the electric main. I’ll post what we end up doing but in talking today, I should be able to power my house (less AC and hot water heater). I won’t be able to test the pro power generator until who knows…
What size condenser do you have? I power a 2 ton heat pump with my truck no issue (plus a bunch of other stuff)
chill_will
chill_will
Will
Montgomery, TX
Cant say off the top of my head, but I will definitely test how much I can power. My buddy didn’t suggest I wouldn’t be able to power my AC, I was just being conservative until I can prove it.
blueovalguy
NY
Ya i just saw you live in Texas. He’s probably right. Everything is bigger there haha
You could however easily power a window shaker for your 10mo old room.
Hullguy
Weymouth, MA
2013 F150 FX 4
Retired Union Electrician
Or connect directly without the neutral, though I am not sure about the safety implications of this.
Thi
This is completely wrong and is causing a safety hazard to you, your family and your house!
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
ThiThis is completely wrong and is causing a safety hazard to you, your family and your house!
Can you explain the safety hazard? Not questioning that it exists, just curious what it is.
EDIT: I meant to say not wiring the GROUND, not neutral.
jeffcrum
Jeff
Slidell, LA
Computer programmer
I think you meant ... Without the ground.
But, I believe the electricians will say the same thing about a safety hazard.
I am wondering if it is possible to put a switch on the neutral ground bond. Then shut of main breaker (and all other breakers), break the bond by shutting of the switch, then connect truck to outlet, and turn on the breakers you want/need.
Of course, use an interlock to make sure the main and generator breakers are not on at the same time.
Hullguy
Weymouth, MA
2013 F150 FX 4
You need three wires for electricity to work in a house at 240/120 volts. Two hots and a neutral. The ground is your safety wire and a house’s electrical system is designed so that your ground wire doesn’t carry any voltage or current unless there is a short circuit. If you eliminate the neutral then the ground will become live. This can cause devices to catch on fire or electrocute people using their hair dryers or can openers!
Hullguy
Weymouth, MA
2013 F150 FX 4
This is what using the correct transfer switch does.
