Powerboost or 3.5L Ecoboost To Tow 7000 lb travel trailer?
docprego
Henderson, Nevada
2018 Alfa Romeo Giulia
I had a Powerboost XLT on order to tow my 7000 lb travel trailer. Then I found out it had a 30.6 gallon tank, and the few videos and forum posts I found showed towing MPG to be around 8 or less, sometimes significantly less. So I switched my order to the 3.5L Ecoboost which has the 36 gallon fuel tank. I figured weighing about 500 lb less than the Powerboost combined with that 36 gallon tank would make it a much better tow vehicle. I believe the Powerboost will not utilize the hybrid powertrain while towing so there shouldn't be any MPG gains and in fact that 500 lb difference will probably mean the 3.5L Ecoboost will have better towing fuel economy.
Am I thinking correctly? Which would you choose to be primarily a tow vehicle?
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Oops! I didn't know you cross posted or I would have answered here. That "other" forum didn't realize you have analyzed payload stickers to death already. I'll cross post my analysis here too, in case anyone cares.
And for what it's worth, for range I'm ok with ~300 miles because my family doesn't like to drive 5hrs straight, we usually pull over at a truck stop or even a rest area if no truck stops. I get gas there just because we're parked anyway using the restroom. So giving up the final 60 miles of range was ok for us, as we can run the A/C while eating lunch now with powerboost. I think everyone is different and would totally understand if someone wants that extra range though!
-----begin cross post----------
My stats are a 2017 EB 4x2 max tow pulling 7500# TT, I settle into cruising speed of 60mph max (my preference) and I get between 9.5-10MPG towing.
I expect the wind resistance and aerodynamics to be the same moving to my new PB. The biggest difference will be the axle ratio. But it isn't as straightforward as I wish it would be, because I'm not maxed out at 10th gear when towing!
When towing my setup, in tow/haul mode it settles into 8th gear max (it would RARELY go into 9th, only a few times I remember tapping the accel on a slight down grade). So there are 2 more gears of less RPM's that would in theory get better MPG, but the truck's computer feels they can't comfortably pull. Since my EB had an axle ratio of 3.55, and it could usually only use the first overdrive gear (8th) but RARELY ever 9th, it tells me that the minimum comfortable towing ratio is somewhere between 3.55x0.854 (3.03 total) and 3.55x0.689 (2.45 total). The truck will pick 8th so that it exceeds the minimum it needs, but *maybe* it is close to being able to use 9th, because I got it a few times....
Ford F-150 Lightning Powerboost or 3.5L Ecoboost To Tow 7000 lb travel trailer? 1615353244263
The new PB is going to have slightly different effective ratios. 8th gear would put it at 3.73x0.854 (3.19 total) while 9th gear gives 3.73x0.689 (2.57 total). What I'm optimistic for, and it would be pure luck, is if the required towing gear ratio for my setup can be met by a 2.57 effective ratio of 9th gear, I will be MORE efficient than my EB. If I settle into 8th gear again, I will be LESS efficient than my EB.
All this is going to be specific to every individual's towing resistance, which is a function of the weight and (mostly) aerodynamics at your cruising speed. So everyone's will vary. I would not take 8MPG as the golden reference, you need someone like me that is towing the EXACT same rig in order to do a proper apples-apples report and I will absolutely be over analyzing this when I eventually get my dang truck and do some camping.
laujoyjoy
King
NJ
2021 F150 Platinum
I don't think this is true. When you switch to tow haul mode, the truck will limit to 8 gears and disable EV mode (i.e. electric only mode), I don't think it will stop the electric motor assisting the engine during tow.
docprego
Henderson, Nevada
I'm not sure what the facts are regarding this. I've seen several mentions that the hybrid powertrain is essentially inactive in tow/haul mode. One person stated that it is to avoid unnecessary strain on the electric motor and battery. Again I am not certain so clarity here is still needed.
kmayer
Kevin
Seattle
99 F250
Web Design Agency
I don't know the answer to this, but my money is on the powerboost helping while towing given the direction that automobile powertrains are headed coupled with the fact that towing is when you most need the extra power.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
If I had my got damn truck I would tell you guys! I plan to have fun watching the "power distribution" screen when I tow to see if the electric ever kicks in while I tow. I don't *expect* it to, but if the computer decides it helps? Well great! Maybe I will get better than my current 9.5MPG towing in my EB.
docprego
Henderson, Nevada
To revitalize this thread, has anyone had any experience towing with a Powerboost recently? I am most curious about MPG numbers. I'd love to know if the Powerboost will give me any MPG advantage over the 3.5L EcoBoost when towing.
Thank you.
docprego
Henderson, Nevada
My VIN# was issued last week after I started this thread and therefore no further changes could be made. But that was ok as I decided to stick with my order for the 3.5L Ecoboost. My build date is April 19th.
