Pro as tractor replacement?
PV2EV
For some of what I do on the farm I tow a simple implement. For other work an implement uses the PTO, and needs a 3 point hitch connection only because the PTO. In the rare case, an implement absolutely requires a 3 point hitch. And for some orchard work there are task specific vehicles that could be a towed implement if done differently.
Assuming 30A ProPower (8HP) would be enough, I think some of the these implements could be converted to a towed electrical solution, saving a huge amount of diesel if towed behind a Lightning Pro.
An example would a large rotary mower. Replace the gearbox with an electric motor and you are good to go. You may/would have to find a way to float the hitch? And if having to backup, not jackknife, which is not a problem with a 3 point hitch. The place the Pro not work is very poor fields, or sloped terrain.
I only post this as the few electric tractor solutions are lacking (mostly capacity/power).
Aminorjourney
Nikki
Internet
www.transportevolved.com
I mean the biggest challenge is turning circles and overall length.
My truck was in a farm last weekend moving a tiny home. We got it out of its position but we couldn’t use the truck to get the house in a new location because turning circles.
8HP isn’t going to run a rotary mower of any decent size. Certainly not one wide enough to cover the width of the truck.
I agree on the turning radius issue as well.
Firestop
Firestop
So, other than the turning radius, how did the truck perform?
PV2EV
PV2EV
Agreed 8Hp is not much, however, when you remove the PTO, shaft and gearbox, the required HP should be much less. My tractor is 30HP at the PTO and runs a 72" heavy duty Landpride no problem (when the radiator is clean). So a bit less (60"?) might work.
Forgot about the turning radius, which makes farming use near impossible.
Aminorjourney
Nikki
Internet
PA Lightning
Tbone
PA
Lightning Pro
Amazingly well.
Did you have the rear locker engaged?
Aminorjourney
Nikki
Internet
I have thought that farmers would be a PRIMARY use case for this electric/battery TRUCK. It makes all the sense in the world to be able to drive anywhere on your farm, off-road, or on the road, and take care of your duties. No idling. No added engine noise. And few farmers are going more than a couple of miles per DAY.
Maybe it's not a use case as a 'pure' tractor, but it will certainly be able to do many duties that other MUCH HEAVIER equipment is now doing. I can also imagine that in the future we will see SuperDuty versions, with even MORE torque, for these types of needs. Turning radius may be a negative in the short term, but I can imagine that if a Farmer really wants to, it could do the job, especially with larger/off-road tires.
I think that many businesses that are 'contractor-based', such as utility companies, forest service agencies, land surveyors, mobile mechanics, etc., who tend to travel often to business 'sites' and like to leave their vehicles running, are the PERFECT candidates for the EV truck, not to mention the power generation capabilities versus the typical loud and heavy onboard generator.
I have a 24HP running a 5’ mower and my experience is similar to yours - if the radiator isn’t clean, it overheats, suggesting it’s right at the limit. Empirically, we’re coming out at about 5HP per foot. Even if we assume 50% loss in the drivetrain and gearbox, 8HP electric comes out to about 3’.
ColeCisneros
Cole
usa
BMW
developer
The idea of using a 30A ProPower for some of your implements is pretty intriguing, especially for those tasks where it makes sense.
For something like a rotary mower, converting it to an electric motor sounds like a smart move. You'd likely need to work out the hitch and maneuvering details, but it could save you a lot in the long run.
And by the way, if you're still on the hunt for machinery or equipment for your farm, I recently came across machinerydealer.co.uk. They offer a range of new and used plant machinery sales, which might come in handy for your diverse farm needs.
