Pro Power Ground Fault?
Biggerfish
Eastsound, WA
F150 Lightning Pro
Business owner
Sorry if this has been covered already. (Searched but could not locate exact subject). I just got my 23 Pro a few weeks ago, and am still playing/learning. Yesterday, I was monkeying around, and pressed the Pro Power Test button on the console and got this message:
Ford F-150 Lightning Pro Power Ground Fault? 84CA4219-8346-4580-85EF-A13D43268F2D
Do I still have a ground fault? And if so should I Reset? Thanks in advance for your guidance.
roadhouse
F150 Lightning Lariat ER
You have a ground fault because you pressed the 'Test' button to trigger a ground fault. It's just a GFCI - you need to reset it for the outlets to work again.
Biggerfish
Biggerfish
Eastsound, WA
F150 Lightning Pro
Business owner
Ah. Lol! The modern man’s GFCI green test button! Got it, and thanks a bunch!
srspring551
Scott
WI
Very bad wording on the screen. My dealer also had trouble figuring out exactly what it was saying. It should be clear that it is a "test" and what the Alert means.
Biggerfish
Biggerfish
Eastsound, WA
F150 Lightning Pro
Business owner
Agreed.
roadhouse
It makes sense - the system doesn't know it's a test or a real fault, it just reacts because the GFCI was tripped. You'll see the same message if you use a standard GFCI outlet tester (or a paperclip) to perform the test, rather than the test button.
In an ideal world this is the best process - if you program the system to be aware of the test, then when you push the button, you're just testing the 'test' process, not the 'actual fault' process.
climateguy
Ferndale, Washington
2021 Bolt, 2024 Flash, MaxTow
I'm guessing that the problem described in the NHTSA report was that only some vehicles produce that popup message after a ground fault test. If this is correct, people who see the message have a normally operating system.
I was performing the ground fault test as part of an attempt to diagnose a weird set of symptoms. I've been using the Pro Power system only a few times. The popup announced that a ground fault was detected. I wondered if that meant that my system had a ground fault that was not severe enough to cause the power to shut off until this test but was enough to have something to do with the weirdness I was investigating.
If I was reporting my experience as a software tester to the engineers, I'd say, use a different popup message after a test than the one you present to the user when the system has detected an actual fault. How about "This test created a ground fault to see if Pro Power would turn the tested outlets off. The test was successful. To turn the outlets back on press reset."
