Joneii
- Sep 20, 2022
- Central PA
- F-150 Lightning, Tesla MY
My normal trailer is an Airstream that we take camping in milder temps, so when I needed to tow this box trailer in cold weather to an area with little charging infrastructure, I paused to do some math. My Airstream gets about 1.2 m/kWh (averaged over about 700 miles of towing in 50-70 degree weather). I knew the box trailer would be less efficient, plus the temps were between 20-30 degrees. I figured on about 0.8 m/kWh and determined I could get the job done.
The first challenge was to pull the trailer out of its frozen parking location which was off road in a field. Thor (my Lightning’s name—go ahead and laugh, but my vehicles all get names) had no problem with this. The stock AS tires didn’t slip abut as the frozen ground was yanked loose when trailer was hitched up. The GOM told me I could tow this brick about 160 miles on my 90% SOC. Of course I knew that to be false as my own calculations were closer to 100 miles. As I have to climb a 3 mile 8% grade in the first 5 miles of the journey, I anticipated some shocking GOM changes. The numbers quickly went from the optimistic 160 miles of range to a more appropriate 125 or so. I didn’t panic at the 0.4 m/kWh reading either as I knew this would improve over the course of the trip. In the end I averaged 0.9m/kWh (slightly better than I expected).
Overall the truck tows great and if you do a little pre-mission planning, it can be quite enjoyable. I just wanted to let people know that this can be done with a little planning.
