Replacing OEM lug nuts to avoid future swelling
Jus Cruisin
Tim
Metro Detroit
2021 F150 Agate Black Platinum 4X4 Powerboost
Very retired
jwgreene
James
Chattanooga, TN
2021 F-150 XLT supercrew in leadfoot with 5.0
Does anyone have a model # or link to the correct black Gorilla lugs for the factory 20” wheels?
jwgreene
James
Chattanooga, TN
Doyouevenboost
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Thanks. I had ordered some from an EBay seller but they aren’t the same model #. The ones I ordered are 91148BC which are 1.40” tall vs 1.62” tall. Aside from that they are the same. I wonder if they will work?
I ordered the ones I linked for myself, I pick my truck up Wednesday, so I can’t confirm fitment.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I also want to replace my factory lug nuts as my neighbor's Ford Fiesta nuts swole so bad, he was stranded on side of road because lug wrench wouldn't fit.
I was looking at some slightly longer lugs for my Lightning not long ago. Does anyone have some good recommendations on some longer, good quality chrome lug nuts for our Lightnings? I see these on Amazon but looking at the price, they seem too cheap? What do you guys think?
Ford F-150 Lightning Replacing OEM lug nuts to avoid future swelling Screenshot_20240809_100606_Amazon Shopping
Wheel Accessories Parts 24 Pcs M14x1.5 14x1.5 Thread Bulge Acorn 1.90" Long Lug Nuts Chrome 3/4" 19mm Hex Fits 1999+ Chevy Silverado GMC Sierra 1500 2015+ Ford F 150 Nissan Titan XD 2019+ Ram 1500
https://a.co/d/cGfqWKc
I bought a cheap set on Amazon for a 2012 F150. They worked, but I wasn’t real happy with them. The OD of the taper was undersized, so there was a very small part of the seating surface on the wheel exposed.
Did you notice this warning? It describes my issue exactly:
Ford F-150 Lightning Replacing OEM lug nuts to avoid future swelling IMG_0966
COrocket
F-150
I’ve had good luck with Gorilla “OEM” style lug nuts. They seem identical in dimension to the stock ones. It is a common problem for aftermarket ones to have less contact area
Lightning Rod
North Coast
I thought I'd buy them from Amazon and compare them side by side and you are 100 percent right. They ought to be ashamed to even sell these. I'm returning them asap. Thanks.
Ford F-150 Lightning Replacing OEM lug nuts to avoid future swelling 20240811_220209
Ford F-150 Lightning Replacing OEM lug nuts to avoid future swelling 20240811_220214
Ford F-150 Lightning Replacing OEM lug nuts to avoid future swelling 20240811_220240
COrocket
F-150
Gorilla 61148CX or 61148BCX are the part numbers for chrome or black
Lightning Rod
North Coast
These look solid! Does Gorilla have some that are longer than 1. 65 inch? That is the same length as the factory. Nuts that sticks out more would look really nice against the Lariat/Platinum rims. :cool:
COrocket
F-150
I don’t believe so - the 61148FS & 61148FSBC are the only other alternative that Gorilla lists as compatible. It gives a different look to the tip of the lug nut - but it’s still 1.65” long so it won’t stick out any further.
