Scorpio3d
SS/IBA car wash owner
This area of the country is probably my favorite. I do like green, but being able to see the geology is just my kind of mental health reset.
I like to see all aspects of Mother Nature.
The world is an amazing (if not sometimes insane) place!!!
21st Century Truck
Martin
Not a rock crawler, but at least it can do some offroading.
A trick known amongst some off-road drivers to significantly increase traction of OEM or basic street tires for temporary off-road use across rocky (i.e. slippery) or muddy terrain is the judicious use of modern thin snow chains with diamond-shaped segments that limit surface slippage in many directions.
Snow chains add considerable traction on snow and on hard ice... they can do the same to increase traction in warm weather off-road conditions.
This traction increase will of course not compensate for our Lightnings' shallow front and rear departure angles. However, I will have my Rud GRIP 4x4 chains handy the next time we will be in the Moab area, just in case ;) .
SpaceEVDriver
SpaceEVDriver
Arizona
I would be careful with the Ruds. I think they're slightly over-sized for Ford's recommendations (no larger than 15 mm, class S). And they only recommend using chains with the 275/65R18 tire size.
21st Century Truck
Martin
Gotcha. I've had them on already this Winter.
The issue, if any, lies with the front wheels and a narrow chain clearance on the outer limits of their turning radius. The rear wheels are fine with the chain clearance.
SpaceEVDriver
SpaceEVDriver
Arizona
Ford doesn't recommend putting chains on the front, which is unusual in my experience.
Ford F-150 Lightning Road trip to Moab and Canyonlands National Park, including some light offroading Screenshot 2025-03-26 at 10.01.07 AM
21st Century Truck
Martin
Yeah. When I tested my chains, there was the potential for interference at complete full turns. From memory, the potential interference was with the ends of the upper control arms. The wheel had to be at full lock for this to even potentially happen.
I tested the range and, personally, being very familiar with snow chain driving on many vehicles, I understood how to drive with these chains and this vehicle, and what to avoid doing ;) Slow and careful usually carries the day when using chains, on any suboptimal surface.
Brons2
Mij
Cybersecurity
Nice report, I'd like to try some of this stuff with my truck. Moab is on the way to my native Oregon using the most direct route, so it would be a good place to stop in the summertime anyway.
nodoubleg
‘15 Jeep JKU, ‘89 E-250, ‘98 Dodge Ram 2500
Last year I used my Lightning to tow my Jeep JKU out to Easter Jeep Safari, and the Jeep was the main “toy” I used off roading. But I did take my Lightning out on a portion of Fins ‘N Things, just for the haters.
I had the stock (and garbage) Hankook AT tires aired down to ~20 psi. I had the lightning on two or three tires at some points. The 50/50 weight distribution had this thing balancing similarly to my Jeep, actually.
the long tail of a pickup does not match well with Moab. There were several gladiators out there with an exaggerated rake, with 6+” lifts in the rear to attempt address the bad departure angle of a pickup. Buddy of mine got on the radio and asked my why my Ford was “making gladiator noises” going down a particular obstacle.
The drivetrain makes for relatively easy precision placement of the truck. I love that you can drive these “two-footed” like an automatic if necessary. Easier control than my 6-speed Jeep with gearing that’s still a bit too high.
Ford F-150 Lightning Road trip to Moab and Canyonlands National Park, including some light offroading IMG_5023
Ford F-150 Lightning Road trip to Moab and Canyonlands National Park, including some light offroading IMG_5109
bthanos
Bill
2023 F150 Lightning Platinum
System Architecture (retired)
I will be interested to read the rest of your story. Exploring the Bryce, Zion, and Capitol Reef NPs is on my EV desert challenge list. While there is a nice concentration of DCFC chargers in Moab, the area to the SW basically has none. I wish Rivian would put one of their cool charging stops between Zion and Bryce; I would cheerfully pay their high price for electrons for the convenience and amenities they offer at their new location near Joshua Tree NP.
We just did Zion and Bryce. We stayed at Zion Canyon Campgrounds and RV park. Got the 50A site and used a 40A AC charger to fill up overnight. We drove to Bryce the next morning and returned with 30% charge (170 miles RT). The site cost is $110 per night and it’s right in Springdale near the entrance to Zion.
Ford F-150 Lightning Road trip to Moab and Canyonlands National Park, including some light offroading IMG_2859
Ford F-150 Lightning Road trip to Moab and Canyonlands National Park, including some light offroading IMG_2848
SpaceEVDriver
SpaceEVDriver
Arizona
Beautiful!
We used to take our Tacoma to Moab at least once a year (usually on our own, not during events) and have done many of the trails. But the Lightning is so much bigger than the Tacoma and this was our first Lightning trip to Moab, so we played it safe. When we go back, we may add to the list of trails we'll do.
I agree with the assessment that the Hankooks are garbage. I don't even like them for simple road tripping. But I always run the OEM tires down to the wear bars before replacing them, so I have at least another year before I can create the excuse to get better tires. When I do, I will likely get a second set of wheels as well. I wish we could put 17s on this truck without a weird offset--I prefer my tires sit under the vehicle entirely, especially on such a wide truck as the Lightning.
I agree with you about the precision of the Lightning's throttle response. It's the best I've ever experienced, and I think it's just down to being an EV with consistent throttle placement: put the pedal in this position and this is what the motors will do. Every time.
bmw325_num99
Jordan
Chicago, IL
2022 Lightning Lariat ER, 2024 Kia EV9
After about 5 miles, we began encountering more difficult terrain and made the decision to back up, turn around, and hike the rest of the way in.
I drove this trail in my rental 4runner last summer.....you made the right call. I would not even take my Lightning with level kit and 35s on this trail. It just got tougher and tougher. Plus, we saw a couple in their 2nd gen Ram that slid off the trail into soft sand and were stuck waiting for a tow. They politely refused help from us.
SpaceEVDriver
SpaceEVDriver
Arizona
Yeah. I've been on that trail in the past. It's a difficult trail, and the full-sized vehicles are just too big for it. I'd take R1S, maybe an R1T, but it's longer. I'd take an R2 if it's capable. But not a Lightning or similarly-sized vehicle.
2sleep
Bob
Western NC
23 Lightning Lariat Antimatter Blue, 2008 Prius
Planning a Road trip on the first half of the Mother Road Route 66 from Chicago to Amarillo. Any suggestions?
SpaceEVDriver
SpaceEVDriver
Arizona
For places, I’ve only driven on I-40/Rt-66 east of Amarillo a couple of times, so I can’t say much about what to visit between Chicago and Amarillo. If you were able to go a bit farther west, I could help out there.
If you’re talking about road tripping with a Lightning, I’ve done a lot of that and am happy to answer questions. Others have done more in general and more of your particular route than I, so I’d post a general question in the road trip subforum about what to look out for, which charging areas to avoid, etc.
2sleep
Bob
Western NC
I've done several western NC to Southern Illinois, several to PA and WV and one from WNC to Southern Illinois to Cleveland and on to Niagra Falls. It's a great road trip vehicle!
