Rust notes near the rear motors when looking randomly under the ~TRUCK~
joshtb86
New Jersey
2025 f150 lightning flash
Hope it doesn't deter you from asking questions in the future. :)
There is a lot that has been figured out about our trucks, but a lot that hasn't.
Speaking for myself, I can say I have learned quite a bit from the questions people ask when they encounter something unexpected, or have some kind of major system failure (knock on wood), or just another glitch caused by an OTA (over the air) update.
My mantra is put your 12v battery on a maintainer with an AGM mode when you are not using the truck and you will avoid a lot of error messages and other problems like premature 12v battery death...so before that happens to you, here's a suggestion.
-- Reading the forum about that issue is a good idea! --
https://www.f150lightningforum.com/forum/threads/charging-12v-battery.16979/
thanks, did a bunch of reading on the 12v battery, already have a maintainer on it!
great, it really pays off in the long run!
3rd rock
Automotive Technician
No need for a maintainer. If you plan to leave the truck sit for more than a month, disconnect the battery, it'll be just fine until you reconnect it. Otherwise just drive it and don't let the fear mongers in here spook you.
joshtb86
New Jersey
Haha they already did, and so did the 12v batteries on sone other EVs so I'm gonna do it
Not 24/7, but the few times q week I'm not driving long or far
I also check the 12v via the OBD2 port every time I drove
Ya, they come standard like that. I have no idea why they didnt paint them at the manufacturer.
It's thick enough to outlast the useful life of the truck without failing due to rust. Paint would cost money and have no functional benefit.
Randall Stephens
Seattle
Jet Builder
Have a 2-month-old 2025 F-150 flash that had been sitting at the dealer for a while. Attached a picture.
Any reason to worry about this? Don't have any actual problems just wondering if this is normal
Thanks
Normal? Yes. However they fixed it on the 2026 models, so I suggest you work with your dealer on a trade-in.
Famous last words...
