Shudder when I hit bumps
Texas Dan
Daniel
Every time I hit a bump at low speed I feel little shake in the front end of my Lightning. I don’t get any shimmy or bouncing going down the highway so I don’t think it’s ball joints or something like that. I’m kind of thinking it’s just soft bushings but I don’t remember the front end shaking when the truck was newer.
Is there something loose in the front end of my Lightning or have I just become more sensitive? Have any of you felt the little shake in the front end? Is this normal or should I be worried?
CyclopsThere
Portland
2023 XLT
I would listen to my instincts for sure. I can't say I feel anything shaking around on mine which is more or less right off the lot.
Rule out the basics - junk in the frunk rolling around loose, rocks in the rims, etc., but if those are ruled out I'd not hesitate to take it in to the dealer or a tire/suspension shop.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello there. I would like to take a closer look at your shaking concerns. To get started, can you please send over a message with your VIN and estimated mileage?
Henry Ford
Desensitization? Take a ride in an ICE truck then see if you still think there's a shudder with your Lightning. If you do, something is loose or broken.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I think I experience that too, almost like you can feel it in the accelerator pedal. I just figure it's normal.
scottmac2000
Scott
Los Angeles, California, United States
2023 Lightning. 2023 Mache GTPE
I have a 2023 Lariat Ext range. I have noticed a slight vibration once in awhile when hitting the lane markers. It is almost like a resonance. It goes away quickIt is nothing that a passenger would feel.
Ford Motor Company
F-150 Lightning
Hey, Scott! I can take a closer look into your shuddering concerns should you need further assistance. Feel free to send us a PM with your VIN and the dealership name/location and I'll get right on it! To send a private message, just click on our username and select "Start Conversation".
Texas Dan
Daniel
The Ford dealer said they couldn’t find anything wrong with the suspension. Maybe this Texas heat is making the bushings soft. Anyway I’m not going worry about it anymore unless it gets a lot worse.
