maineiah
US
2024 Ford Lightning Platinum
Rough numbers coming from Maine weather and driving:
Stock - 22" Platinum rims and General Grabber HTS tires @ 275 50 22
Each wheel (rim and tire) weighs 87Lbs.
At 42PSI, 70 Degrees, 80% 70mph highway, 20% 40mph +/- rural = 2.1 m/kWh
Aftermarket:
18" Granite Alloy rims, 275 70 18 BF Goodrich KO3s. They poke just a little. No rubbing, almost same diameter as factory, just a 1/4" taller and 1/2" wider.
Each wheel (rim and tire) weighs 92Lbs.
At 42PSI, 70 Degrees, 80% 70mph highway, 20% 40mph +/- rural = 1.7 m/kWh
At 42PSI, 47 Degrees, 80% 70mph highway, 20% 40mph +/- rural = 1.6 m/kWh
General notes:
With aftermarket setup, truck handled fine, little more spongy than stock. Highway noise was noticeably louder, but not bad overall.
I've since gone back to stock for the summer for better handling / feel / noise / range for summer highway adventures.
TireRack link (not affiliate):
https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=6408963SBG25B&wheelMake=Granite+Alloy&wheelModel=GA640&wheelFinish=Black&autoMake=Ford&autoModel=F150+Lightning&autoYear=2024&autoModClar=275/65-18
https://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T/A+KO3&partnum=77SR8KO3RWL
Ford F-150 Lightning 275/70/18 KO3 tires on a 2024 Platinum - specs & efficiency data IMG_0217
Ford F-150 Lightning 275/70/18 KO3 tires on a 2024 Platinum - specs & efficiency data IMG_0220
Andrewbens
Modesto
Lightning
Mechanic
I bumped my K02 tires to 52psi and my range increased quite a bit and took it to American tire after 10,000 miles and the wear was 100% even across the board.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
I was planning the same: two sets of tires, the stock set for summer, and a more aggressive set for winter. Just take the range hit as a cost for traction in snow.
abcut973
Anthony
Denham Springs
I'm on 35" 12.5 r18 K02 + level kit and do 1.6 miles/kwh @ 70mph. I'm averaging 2 miles/kwh since ownership because my daily commute is 50% hwy 50% city and that hwy stretch is 65 limit.
Phil D
phil
2024 Ford F150 Lightning Flash
Law Enforcement
Great info and your truck looks great too!
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
I have KO2 tires at 40psi right now. What was the efficiency increase you saw going to 52? Isn’t that pretty high? How much wear did you se after 10k miles?
