Bed Liner for Lightning Pro
Ffxdude
22 Lightning Lariat ER
That's what I do. On the recent Powerboost acquisition I took it down for a spray-in. They did a great job removing all the components in the bed and the tailgate. Then I throw the Weathertech bed mat in on top because it is less slippery and absorbs the shock/bounce of items bouncing or rolling into the vertical surfaces. Weathertech bed mat covers the first few inches of the walls.
Pics below are after a couple of days of chopping up fallen trees from a recent storm. First the Powerboost kept the lights on during the power outage. And then relocated cut limbs to the burn pile. Bed needs a washing, but the sprayin hasn't marred even the tiniest. Cleans up like brand new.
Looks great! Which spray in did you get?
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
It was done by a local company that multiple dealerships in my area uses. So I don't know whose product (brand) they spray. But I've seen their work on trucks now for many years.
Xtreme Bed Liners of Pearland
https://www.goproxtreme.com/
Maxx
Maxx
Can you share what you have right now? You mean the whole liner slides out of the bed?
I have a 2002 with Line-X bed liner and it has held pretty well over the past 20 years.
2003 Frontier. It looks like this. I have no experience with anything else so I wouldn't know any better if an alternative is better. The input from everyone here is priceless for me. What I meant was I back up the truck to the dump and push all the yard trash in one shot and everything slides right out (not the liner). I don't use it for work just light duty home maintenance
which is probably why it has held up well.
Ford F-150 Lightning Bed Liner for Lightning Pro 1633835654199
3putter
2012 Pilot
My choice for the bed will be the same as what I currently have. The Bedtred Pro from the makers of Bedrug. It looks like it's sprayed in, has a rubber like surface so nothing slides around and won't mar the bed finish as it's held in place with velcro strips. It's impervious so it's easy to rinse out and is easy on the knees if you need to crawl in for what ever reason.
Have had mine for almost 8 years now and no complaints at all.
That bedtred looks really good. Thanks for the tip. Would it really not get too dirty if I load a bunch of mulch right on top of it?
Silenze
Wi
Are the drop in bedliners different on the hybrid f150? I dont have any cutouts for electric on mine. I have a gas 150.
GarageMahal
JT
Data Wrangler
They should be same for 2021 and later with in bed power.
Pedaldude
Arizona
Don't forget the extra weight will hurt range! :p
I work with sheet metal and plate a lot, so I am not a fan of the rubberized liners, since they grab at edges. The slide in plastic ones are even worse and also the ribs that make them rigid bite into sheetrock and chews up the corners unless I load a piece of plywood first.
A super cheap option is a horse stall mat from Tractor Supply, they weigh around 100lbs and really help make the truck more quiet over bumps. The dimensions are 4'X6' and they are 3/4" thick.
Ford F-150 Lightning Bed Liner for Lightning Pro E11DC436-42E0-4C5A-8C56-055C1A231DA7
Solar_EE
Roger
F150 Lightning XLT Ioniq 6 AWD
electrical engineer
I am a bit different in that I prefer a bed mat to a bed liner. I like how grippy the rubber is and it is substantially cheaper.
My plan is to take the bed mat and tonneau cover off of my 2016 and use them on the Lightning.
I cut 11" from my 2016 bed mat and it is now in my 2022 Lightning and it fits nicely. Actually this mat was from my 2010 F150- nice heavy rubber mat and the bed underneath looked brand new when I removed it from my 2016.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
I personally prefer the drop-in hard plastic liner with the ribs running front to back as OP shows in their previous truck.
Yes, its more slippery. That is a good thing if you ever have to unload your truck with a shovel. Anything soft or rubbery, or with ribs going across the bed is going to make unloading the truck with a shovel much more of a chore as the shovel edge snags on the liner.
Also, the drop-in liner that goes all the way up the sides and front is great for stuff like dirt, yard waste, etc. You can get it all out without any of it lodging under the edge of a bed mat.
When hauling individual objects like furniture, 24 packs of beer, or a bucket of baseballs, the tradeoff is that you will need to strap them in place to keep them from sliding around.
RickKeen
Rick
F150L SR Pro
Probably not as common use case with the F150 Lightning with its 2000 lb payload (or as low as 1600lb with optioned-up versions) and shorter bed, but in my Chevy 2500 with 6.8' bed and 3000 lb payload, I also occasionally haul loads on pallets or in crates. The drop-in plastic bed liner lets the load easily get pushed by the forklift and slide to the front of the truck when loading. Similar ease to slide to the back if unloading by forklift.
CRAIGC540
Craig
Moreno valley
Technician
This is my plan also.
The mat holds things in place, Maybe when the sides of the bed get scratched up i will get a spray in.
Blaster
VT
F-150L PRO, VW ID.4
The black armour bed mat has worked well for me. Comfy at the drive in, it grips well so nothing moves around, seems like it can take a beating too. I like the philosophy that when the bed gets scratched up I can make it new again later with line-x.
Ford F-150 Lightning Bed Liner for Lightning Pro PXL_20220822_214041751
for those who might want a 'carpeted' bed, for not only protection of the bed and sides itself, but also the ability to easily climb in and move around in, the BedRug full bedliner is fantastic - I LOVE IT.
Firestop
Firestop
I agree! The self-install, even around the ProPower, bed lights and the bed light switch, is doable with a professional look….it just takes a little patience and forethought
