Nightshade
Aidan
Alberta, Canada
'22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
Sup/t. Wildland Firefighter with Alberta Wildfire
Anyone looking for DRL LED Bar to go from dimmed to boosted bright, this is the only forscan mod you have to do. Works perfectly in all modes, including Bambi mode and marker mode. Stays bright all the time! Huge thanks to @Hectort713. Confirmed working in 2021 F-150 XLT, Lariat and Tremor. Other trims, comment below if working. As always, make a backup before doing this.
BCM: 726-42-01 -> x2x2 - xxxx - xxxx
*do at own risk.
EDIT; also works on ‘21 F-150 Platinums.
Ford F-150 Lightning DRL LED Bar brightness boosted using Forscan 3C4853F1-EB61-4CF0-B553-81798E797C55
Nightshade
Nightshade
Aidan
Alberta, Canada
Nightshade
Nightshade
Aidan
Alberta, Canada
Some shots from last night.
Definitely looks 100% better and I didn’t even have to use the low beams in the city during night time either; with those on mode 2 + fog lights, was great. Love it!
—Works on Platinum too, will add to the original post.
Nightshade
Nightshade
Aidan
Alberta, Canada
Will it dazzle other drivers?
I’d rather be considerate than look cool.
Really depends. Reason why Ford left it dim from factory is because they had complaints that it was too bright.. personally it isn’t. I’ve had this brightness boosted on my 2016 and 2020 F-150s, no issues in my area. Did the same on my 2021, no issues at all. So far I’ve gotten many people near me asking me how I did it lol, they want their LED brightened up more too. Really comes down if your preference.
Sapphire
Chicago
2021 F-150 Powerboost Platinum
If your low beams are off at night, doesn’t that mean your taillights are off too (when not braking, of course)? I see non-F150s running just DRLs with no taillights in the city frequently, and they’re tricky to see when behind them.
Platinum Peasant
West Sacramento
Forscan can enable your rear DRLs to be on with the front ones. I did that for mine for an even look after boosting the brightness.
Nightshade
Nightshade
Aidan
Alberta, Canada
@Platinum Peasant is right, you can choose which DRL modes you want in Forscan. However for me, my DRL is disabled on mode 1 where my DRL is auto on mode 3 on the switch. For low beams off at night, no. This only happens if the truck is on mode 1, which is DRL only (standard is front led bar stays on with tail light off). If you use mode 2, the low beams stay off but the front LED bar plus the tail lights stay on. If you look in the first post or the photo attached, you’ll see the truck is in mode 2. Front LED bar + markers are on as well as the fog lights AND the tail lights are on (mine is LED so my rear end has the tail light LED bar too).
Ford F-150 Lightning DRL LED Bar brightness boosted using Forscan BA9A6A1E-9472-4C6D-829A-389758C0F08E
CK.MECHA
Atlanta
Motorcycles
Question @Nightshade , looking in the digital owners manual it seems to indicate the conditions below need to be met for the DRL to be on.
Well, I programmed these values, step out to look, and my DRLs are not on regardless of the position of the headlight switch. Is this because it is in park, did you take your pictures in neutral?
Ford F-150 Lightning DRL LED Bar brightness boosted using Forscan 1637695004067
Nightshade
Nightshade
Aidan
Alberta, Canada
DRLs turn on from the factory when the vehicle is in Drive, not in Park. If you put it in Park, it will shut it off regardless. The one in my photo is my side marker mode (turn the light switch to mode 2). You will get the same thing as I did! However, if you'd like to test your DRL (Mode 1 on the light switch or in Mode 3 (auto) during the day), I would suggest you leave the door open, apply the electronic brake (like a hand/foot brake) and shift from Park to Neutral. If you attempt to do this without opening the door, the shifter will automatically go from whichever the shifter is into Park, as soon as you open the door. Be sure you are on a flat surface when attempting to do this. Don't put the shifter to Drive when attempting to check your DRL. Another way, find a reflection during the day and attempt it by watching through the glass or reflection.
CK.MECHA
Atlanta
Motorcycles
Thanks for the response. Follow up - you keep mentioning "modes". The manual doesnt designate any modes so what are you referring to here? Are you referring to the four positions of the exterior lighting control dial which Ford calls A, B, C, & D?
Nightshade
Nightshade
Aidan
Alberta, Canada
No problem! Yeah the light dial that control your exterior lighting, sorry for the confusion; I got used to calling it mode lol.
Bocephus
Bocephus
MI
2021 F150 XLT 302A 3.3L
Entertainer
I made this change and the upper light is super bright. No noticeable change to the lower light. Is there a way to change the brightness of the lower light or is this the way it is? Thanks
Ford F-150 Lightning DRL LED Bar brightness boosted using Forscan 1637755744508
