SudS2k
Los Angeles
2021 F150 Powerboost Lariat High, S2000
Real Estate Investor
Thank you all for your work on Forscan, especially Livinitup. My first post here, but I've been following the thread for about a month. I'm going to attempt the autofold mirrors, and auto up/down windows myself this weekend. My truck is a 2021 Lariat 502a with the 7.2kw package, no 360 or blue cruise.
Has anyone done any research on propower onboard settings? I'd like to have my power tool battery chargers mounted in my bed and constantly charging, but every time I get in the truck and something is plugged into an outlet, the truck detects it and message pops up on the screen asking to turn on power to the outlets or not. You have to select yes or no before shifting into drive. I'd like it to just send power to the outlets (at least those outlets it detected a device) all the time and without a prompt.
Not sure if this is a safety concern, or if there are other unforeseen consequences of this... but I'm willing to take the risk. If someone can point me in the right direction on forscan I can look into it. I also do a lot of camping, so this would help with that too.
Livnitup
Livnitup
2021 F150 Platinum
Disabling Pedestrian Alert Speaker - credit to Airborne_Ape for discovery
IPC 720-09-02 x*xx xx-- - if you have 4 then change to 0, if you have 5 then change to 1 AND disconnect PACM under the glovebox according to the video below. This has been added to the Common Spreadsheet.
BMWtoF150
Marty
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
I have what may be a dumb question. Do OTA updates change the same code that Forscan changes? What I mean is if I have saved the as built and then an OTA update comes down, is the as built backup obsolete and needs to be backed up again?
Livnitup
Livnitup
2021 F150 Platinum
It's possible for that to happen but usually does not on the majority of the modules but GWM is one that comes to mind as 50/50.
AutonomousHybridF150
Kristopher
Pensacola Fl
Adjuster
Did this one late at night I was so excited to learn a proper way of shutting that OFF forever!
Kristopher
Pensacola Fl
Adjuster
Wouldn’t it just be easier to tap into the interior cab 20 amp outlet for the chargers? It would be on each time you crank the truck. Also, wouldn’t leave your pro power port open to the elements all the time.
SudS2k
Los Angeles
Correct, but all my tools are in the bed of the truck, it would be more convenient to grab the batteries from the bed as well. I also have a tri-fold tonneau cover, so I'm not worried about the outlets being exposed. More concerned about people stealing my tools.
I've looked into mounting a battery charger in the cab, but they usually interfere with legroom and loads inside the truck. I once had a tool battery charger set up in the cab of my older truck (2015 same spec, except not hybrid) and I would routinely knock the plug out of the outlet while throwing stuff in the back seats, to the point the outlet cover broke off.
I also have the full leather interior, so generally I try to keep the it nice in the cab, dirty in the back...
But the battery chargers are just one example, there are many other uses cases for having the outlets on all the time without a prompt
  • Air compressor charges while driving
  • Off road lighting
  • Parade vehicle, etc
I understand that you wouldn't want the outlets energized all the time. But at least the outlets that the truck has identified something is plugged into it, I would prefer these outlets be energized without needing an onscreen pop-up and shifter lockout. I mean, I plugged it in there for a reason, right?
Kristopher
Pensacola Fl
Adjuster
Well, with what I am recommending, this would give you exactly what you are wanting. I’d you simply splice into the in-cab electrical, this will default to on, supplying power to anything that can plug into your 20 amp outlet.
Simply, tap into one of the two 20 amp 110 volt outlets in the cab, and that will give you most capabilities needed. If you need to run something more substantial, you can kick on the pro power for your truck’s maximum. But those outlets are 20amp circuit switched, and you will never get an alert for having something plugged in when you out it in drive.
Either way you’re going to have to tap into 3 wires somewhere. Just use stranded 12 gauge to connect the hot, neutral, and ground, and then make your dream harness for your chargers and other :)
SudS2k
Los Angeles
Part of me thought that was what you were suggesting... not sure how easy it is to open up the outlets on both ends, but the wiring seems simple enough. I'll take a look at a service manual on how to open up the outlets.
Thanks for the suggestion, this sounds less risky than the Forscan option. That being said, if there was a Forscan solution, it would be easily reversible and less work.
SumGuy
F150 (perpetually on order)
Drugs
I am new at this, but I dont see the same values as listed in the reference table.
for example, I was attempting to disable the double honk, but my values are already at "0", but the guide states to change the value to "0"
Here is the guide:
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1644708493603
and here are my values:
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 1644708530851
I have the double honk currently. What value am I supposed to change?
SumGuy
Drugs
Looks like there is a new rev of the file. I clicked the link in the first thread.
Where is the link for the new file rev?
Edit: Ah, I clicked the link for the prior MY. I only tried the double honk and removing the artificial sound. I will restore the values and look at the right list.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
I have a Job 1 2021 Platinum, would the auto heated/cooled seats work on my vehicle?
C. Mays
F-150 Lariat; Subaru Crosstrek
Project Management
Any other 22MY models find a solution to the Auto start/stop? My truck doesn’t show a PSCM..
Jesse-Infotainment
2024 F150 Lightning Platinum
I would think we need to look at the trucks with Auto start stop removed and see what all was turned off in those to come up with a real start stop removal solution. Now that Ford has an official removal we can see what they did.
I briefly looked and saw a few things I am one of the few that like the Auto start stop though so I havent investigated that much.
