MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
I have a Job1 '21 king ranch and can confirm the auto headed/cooled seats worked for me first try.
every time I try to change the HVAC I get “Service Proceedure has been interupted” error and change won’t save.
any ideas anyone?
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 95C2B92C-A088-46C8-B63A-3E3FA7FDE60A
superfordman
Troy
NE CO
2021 F150 Lariat
any ideas anyone?
I'm in the same boat with my Job1 21 as well, I can't program HVAC at all. Have tried different versions of Forscan and am running a LinkEX as well now and still nothing.
Knickell
Kyle
Mazda Protege, Ford F-150
Hey guys, I need to call on you for some help. I tried to enable "Bambi" mode on my F-150, and now my fog lights will not come on at all. The LED signature lighting works, but the full light will not.
I saved a profile before getting started. How to I reload that profile to the truck, or fix the fog lights to where they come back on?
sysop
Joe
2020 F150 Lariat 145 - 2022 F150 Lariat 157
worker bee
I would think we need to look at the trucks with Auto start stop removed and see what all was turned off in those to come up with a real start stop removal solution. Now that Ford has an official removal we can see what they did.
I briefly looked and saw a few things I am one of the few that like the Auto start stop though so I havent investigated that much.
I ordered mine with the auto start/stop removed to speed up the build. Stop and go is a small percentage of my driving so it would save me nothing.
Portland, OR
2021 Ford F-150
I've started adding FORScan spreadsheets here for anyone interested: https://bit.ly/3cJnYMS
Currently the newest version of FORScan can only change the BCM and 1/3 of the IPC (cluster) versions so when that changes I'll add the other modules as well.
My FORScan tutorial is here: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Much appreciated...does anybody know how to disable the adaptive learning on the 2021 F-150 with Forscan? Or any options similar to that on Forscan?...Yes, I'm one of those people that have the annoying 10 speed transmission that does NOT run smooth at all. I'm hoping forscan can help.
ROBB1
Justin
NC
2021 F150 Tremor
any ideas anyone?
The HVAC module is very slow to write. I was able to do it with a MX+. If you haven’t already, try to optimize your usb adapter latency and turn on auto increase in forscan.
https://forscan.org/forum/viewtopic.php?f=4&t=1763
GolfR
2022 F150 KR PB
I too am on Power Up 1.7.1, and I was also able to use Livinit Up’s sheet to manually change those 3 lines in the 2 modules, reset the APIM, and then the cameras in motion works for me now also! First button press gives hitch cam and second press gives 360 view with cargo cam.
I have a job 1 Platinum Powerboost with 7.2 Pro Power, and Blue Cruise Prep, purchased on 1/15/21. The last update I received notification of was 1.7.1, on 7/28/21, and nothing after that. I have installed the widget and I think it also says I have 1.7.1, so I have included some of the raw data for assistance.
Maybe someone can help me understand why it says Vehicle Not Drivable. And, how can I tell the failed update version?
Bed Cam & 360 Cam In Motion:
Hitch Cam:
Does the rear view camera still have the “full screen not available” black box? I would love to get rid of that!
sysop
Joe
worker bee
+1
MikeYQM
Moncton NB Canada
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Disabling Pedestrian Alert Speaker - credit to Airborne_Ape for discovery
IPC 720-09-02 x*xx xx-- - if you have 4 then change to 0, if you have 5 then change to 1 AND disconnect PACM under the glovebox according to the video below. This has been added to the Common Spreadsheet.
I was so excited to see this, I am at work and ran out and followed the instructions and now I have the truck that I wanted. I do not feel like I own a contractor truck for a personal vehicle. Thank you for figuring this out.
ROBB1
Justin
NC
2021 F150 Tremor
I’ve been using a J2534? Pass through cable. I’ll try another cable.
If you have another cable available, I would recommend giving it a try. Some of the modules can be sensitive particularly the slower ones.
MikeYQM
Moncton NB Canada
I tried both my OBDLink EX and VCX Nano and no luck for either. Both optimized for peak performance.
Jesse-Infotainment
2024 F150 Lightning Platinum
I can confirm it will write to the HVAC, I have written to mine several times. I use the Vlinker FS
MikeYQM
Moncton NB Canada
not for me, no matter what I try, it will not write to HVAC. I get a service procedure interrupted failure every time.
2 cables
2 USB ports
Optimized settings
Write & write to all
Tried writing an unchanged As Built
Ignition off and on
HVAC off and on
HVAC module reset
I’m out of ideas on what could be causing this.
Jesse-Infotainment
