Gnfghtr
Colorado
2022 F150
Pilot
I cannot find the Power Steering Control Module in Forscan. How can I open it up?
C. Mays
F-150 Lariat; Subaru Crosstrek
Project Management
Ruffiano99
Joe
NY
2021 f150
Anyone know if it’s possible to reset or recalibrate the steering angle sensor through Forscan? Having an issue that my steering wheel is slightly off center while driving. Truck drive and tracks fine. Just bothers me that its not dead center.
Did a level and had an alignment done. Its been like that since, i think, dont remember noticing it beforehand.
jcaspar
Sacramento CA
2021 F-150 4x4
Can anyone recommend a sub $200 laptop to use for forscan? I’m a MacBook user so I’m trying to make sure I get the right one.
I was in the same boat and picked up a a really old one from work that no one used. Runs Vista (which came out in 2007) and it works great with Forscan. Get a used one if you can. I am purchasing one now to try out the FDRS module programing which has much higher requirements.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Sounds like they didn't have the steering wheel straight when doing the alignment. That's the only time I've ever had a vehicle with the steering wheel not centered.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
I tried enabling camera on speed, but I didn't get 360 degree camera beside the bed camera. Only bed, hitch and rear view cameras working.
Any help will be appreciated to enable the 360 camera as shown in the previous threads.
superfordman
Troy
NE CO
2021 F150 Lariat
Mine doesn't populate either.
Looks like you both have MY22 trucks so I imagine Forscan doesn't have these newer calibration files loaded for this module in particular. Send a log to them and I bet they can get it added.
ENG430
Ahmad
Kuwait
Any Idea?
Mine SYNC4 v4.0.21136
Jesse-Infotainment
2024 F150 Lightning Platinum
Any Idea?
That is a job 2 APIM software level. You should have cams from the factory. Send me your Vin or look at your build date
ENG430
Ahmad
Kuwait
Bed, hitch and rear cams works in motion, but I need 360 cams works also.
no 360 cams in motion.
This is Vin : 1FTFW1E51MFC37912
GolfR
2022 F150 KR PB
For those who have enabled the cameras in motion, does the rear view camera have a black “full view not available” text box in the middle of it while moving? My 22 came from the factory with the cameras enabled but the rear view is basically unusable because of the box. I’m trying to figure out if any of these changes will get rid of that box.
Thanks
Omodan
Randal
Augusta GA
2021 F150 King Ranch, 2019 Expedition Limited
I purchased a Gateway 11” touchscreen laptop from Walmart for $199 specifically for the purpose of using it with FORScan.
https://www.walmart.com/ip/Gateway-...C116-2BK/754399616?fulfillmentIntent=In-store
I use the OBDLink MX2 as the interface to the truck.
https://www.amazon.com/OBDLink-Blue...qid=1646494876&sprefix=OBD2+MX+,aps,73&sr=8-3
This setup has worked great for me.
Jesse-Infotainment
You have a JOB 2 truck. You should have all cams in motion. Also should have cargo cam in the side stack. Plus full screen cargo cam .. I am going to look at your truck history.
Edit. You have the newest IPMA.. You have the correct APIM version you should of had all cams no changes. BUT it looks like you have made some changes.? You cant go by that sheet it is for JOb 1 trucks.
You need to go to 706-04-01 XXXX-X8XX-XXXX
I saw you are in Kuwait... the truck is an actual Kuwait build.. They disabled a lot of the features for that build. You can still try the 04-01 change it will set it to NA and possibly make cams in motion. I do not know if there would be any other impact.
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
Which proves that any current new X86 Intel or AMD Windows machine will work fine for FORScan. The program is communicating with the truck at very low speeds, so really any x86 windows machine should work fine.
