Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Well if I could go back one day in my life I would start today all over and WAIT before I rushed to do that latest update pack (IPMA/CCM/PSM)
The Cruise Control update failed and left me with a PURPLE CCM. ???
The IPMA has DTC's and for whatever reason, and I don't have a clue, the APIM throws about a MILLION communication DTC's as a result?
Worn out. Tired of sitting in the truck. Lol
Drove it around and indeed I have lost Adaptive Cruise Control.
My luck finally ran out. I must have had 20 updates since January with nary a problem. Arggghhh
iceman77
Pete
2022 Ford F-150 Platinum
Locate CCM, disconnect, wait a little, reconnect, and try a PMI. I have a strong belief that bricked modules can be brought back to life 90% of time! I have bricked my GSM module when I accidentally switched from J2534 to IDS emulation (on VCX nano), and I was able to recover it. Have faith my friend!
All other DTCs are probably a result of a bricked CCM module
iceman77
Pete
Little more info for you Snake:
Ford F-150 Lightning ECU module programming guide using FDRS 1647149017524
Either way, no need to panic. Your module is "Purple" not "Gray". Meaning it communicates over CAN. Its not dead. You need to try to flash it again. If FDRS is a no go we can try ForScan route. I can get you all the files you need. Hope you have a recent config saved somewhere or we can extract from your AB. Ping me in the morning. Me and @Jesse-Infotainment will help you out
Snakebitten
Coastal Texas
No panic. I promise. It's just a truck part, if you know what I mean.
And thanks for the encouragement. Good to see you must be feeling better yourself.
I'll pull the plug on it tomorrow and see if that helps. I'll ping you if I hit a dead end.
I downloaded my AB data a couple of weeks ago from that Motorcraft link I think one of you gurus provided? (if that helps)
I never edited the CCM in Forscan so never backed it up that method.
Regardless, again thanks for the assist. I'll let ya know the progress. :)
Snakebitten
Coastal Texas
Note: it fails the update and the PMI when it tries to block erase some filename I don't remember. Stops at like 3 or 4 of 257 steps.
Barely gets started and pops up "failed, do you want to retry?"
Thekameleon
Chicago
2021 Ford F150
Same thing has happened to me. The CCM failed when trying to erase the blocks.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
Hi.... would someone be able to run my VIN and see what updates I need.
1FTFW1E51MFC37912
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
You found the fix me button when you and I were on the phone. I don’t remember you running the debug. But if it worked, great.
EDIT: I just double-checked my Mongoose. Running debug is not necessary. Debug only enables the logging feature in case you need to send an error log to someone for further diagnosis. If I remember correctly, you found “Fix Me” when you ran either the Vehicle Check or the Device Check.
Yes, it occurred during the Device Check but several users reported it showing when in Debug so it mus have been a timing thing. I just confirmed your findings as well...
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
1FTFW1E51MFC37912
Ford F-150 Lightning ECU module programming guide using FDRS 16471726952041342446617704705878
Your truck has a bunch of updates available
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
These look odd in my AB information. This is for the IPMA. PSCM looks normal.
You’re getting this junk running a Mongoose? Try running the first three diagnostics (Install Check, Vehicle Check, Device Check) under the Support tab in the J2534 Toolbox. The Mongoose should be connected and the ignition on when you run the diagnostics. Correct any errors you find with the “Fix Me” button and then run another network scan in FDRS.
JEB
Northern Illinois
I suspect that Debug didn’t really “find” anything. It probably just logged an error uncovered by another diagnostic.
JEB
Northern Illinois
Thanks alot. I'll ask dealer to update them in the next service.
That is unlikely to work. A dealer will not update a module just because it’s out of date. As long as it’s working properly, they can’t get warranty reimbursement. You have to be able to tie a specific vehicle complaint to a specific out of date or malfunctioning module so they can classify it as a repair.
