Jesse-Infotainment
2024 F150 Lightning Platinum
Still being stuck at 244 / 21281 with no IPMA update yet and the changes from the forscan spreadsheet still give my job1 the fullscreen cameras at speed. Neither those or the changes suggested above will give me cameras on the side cards. Assuming I only get those near the final updates ?‍♂
Oddly enough an APIM and IPC update showed up today but they didn't actually do an update and just did a configure so must have been the sames ones I already did 2 days ago.
Only ipma update will do that
jordandev
Jordan
2021 F150 XLT 302A (on order...)
Thanks. Yeah that's the one I won't be able to do with a Nano anyways since it includes CCM. Will upgrade to a Mongoose if I can get unstuck to see that update I guess.
jperry5835
2021 F-150 Hybrid Platinum
Did you also have to change 7D0-01-02? I’m curious where you ended up.
To be honest I had a lot of stuff messed up in trying to fix the cameras.
Jesse gave me two lines to change but they didn't seem to fix it. It could have been the APIM not resetting or not taking the new values even though I confirmed they were in place with forscan. I reset it about 6 times and then started looking at other things and thats when it went downhill fast. Jesse had me do a configuration on the IPMA to fix what I messed up there and the cameras still didn't work. We just left it at that state for the night and this morning they were working.
the two lines he had me change are:
7D0-01-04-03F4-FC20-40AF
7D0-02-01-8616-420A-0244
I feel like this is what fixed the issue I just didn't have my APIM reset enough to make them active.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Sounds like you had a lot to do. Glad Jesse was able to come to the rescue. Since you didn’t have to change 7D0-01-02, what was yours originally? Did it start with a 2 or an A?
7D0-02-01 is a surprise. We have different values in the first block but the checksums are the same.
Mine: 7D0-02-01 0616 420A 0244
Yours: 7D0-02-01 8616 420A 0244
jperry5835
Mine started with an A
7D0-01-02 A300-C62B-B927
travbz24
Travis
Iowa
21 F150 Platinum Powerboost
Try clicking the refresh button on right of the Green Run button for the APIM and then run the APIM update again. This downloaded and installed the next available APIM update for me immediately rather than waiting.
This tip was GOLD!
I was stuck on the 21281 rev 244 for APIM. APIM & GSM (ghost) updates were the only available. Running the APIM it was clear it was trying to install the same update with no success.
I thought I would be in the waiting scenario for a sync with the mothership until I saw this.
Clicking that refresh option redownloaded the next update. It applied and then unlocked a GWM. Now I'm back in business with updates coming through.
JEB
Northern Illinois
I saw on another thread that Ford just issued a recall to address an intermittent trailer brake failure. The recall involves reprogramming the TRM. It’s unclear whether the software is available yet—the recall is dated 3/25/22–but if you see a new TRM update in FDRS, I’d appreciate it if you would post it.
This is not the same TRM update released earlier this month.
Slappy McGee
South Caccalackey
2021 F-150 Powerboost
Nevermind, I gave up for the night and just let everything sit. This morning the update went without a hitch.
I'm currently in the same boat after getting up to Sync 244. Hoping a long nap and perhaps something in an overnight batch on Ford's servers will get me back in business tomorrow.
ENG430
Ahmad
Kuwait
2021 F150 Lariat 502A
I just received the car from dealer after updating several modules such as : CCM, GWM, PDM, DDM, SCCM, PSCM, IPMA, TRM and DSP.
Still the SYNC version 21136, Revision: 134.
Any help will be appreciated.
Vin# 1FTFW1E51MFC37912
Whoskyle
Kyle
AZ
2021 F-150 XLT
Is your automatic updates switch able to be toggled?
ENG430
Ahmad
Kuwait
Yes.
but never received any updates OTA.
I live in Kuwait so maybe the OTA updates is not received because I don't have the wifi network menu.
JEB
Northern Illinois
Yes.
If you are concerned, you can always get your own 2-day license to FDRS and type your VIN in. You don’t need an adapter to do this. You just won‘t be able to program. FDRS licenses are available in Kuwait and once you’ve input your VIN, you can not only see if there are software updates available, you can pull up the vehicle history and see exactly what your dealer did. If you find evidence that the dealer did not do something you wanted done, you can print out the evidence and take it in.
Jesse-Infotainment
There is NO UPDATE for JOB 2
