4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
Just installed our RetraxPRO XR on our Lightning. Installation was very straight forward. Fits great!
We've got them available here: https://www.4x4truckleds.com/vehicle-specific/ford/ford-f-150/2022-f-150-lightning/tonneau-covers/
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655841350746
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655841357078
Lowest point of bed
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655854323812-png
Highest point of bed
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655854346981-png
Lowest point of bed
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655854368661-png
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655854391660-png
Updated with Q&A from members:
how much space does it take up toward the front of the bed?
It does take up a bit of room. But since I don't transport a LOT Of stuff that's fine for me. If I was a contractor I would use a different cover. Bu for me, it'll work great. I like how solid it is. I don't like the canister BUT they are necessary. I also like that it has the T-Slots so I can use accessories from Thule and Yakima
bewbie
NYC
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655844288089
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655844295164
Ford F-150 Lightning RetraxPRO XR Installed On F-150 Lightning 1655844301997
Oh and Q number 2- did you drill through the spray on liner into the drain ports or did you buy separate drain covers? Saw some folks doing that, buying a factory drain covering just so they don't have to mess with the fully coated one.
drilled the hole - it’s just a drain capnot sure why anybody would buy a second one
installation is pretty easy
Simpso57
Rob
Ford F150 Lightning
What is the exact height distance after the install in the bed? I have something that is just over 22 inches.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
height where? From the bottom of bed tothe underside of the canister?
Griddlez
Griddlez
Metro-East of St. Louis, MO
I really want one of these for for my current 21 150 but I keep putting it off because I don't feel like having to take it off (and putting it on the lightning later). Maybe I should just do it anyway.. can't be that hard to do right? How long did your install take?
Griddlez
Griddlez
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Simpso57
Rob
Ford F150 Lightning
Thanks for the pictures. Can you do one more measurement: bottom of bed to top of cover?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
I mean... you can go measure your bed lol. It's basically the same as your bed rails :)
Simpso57
Rob
Ford F150 Lightning
Good point. Ford says the bed is 21.4 inches or something close to that. I was hoping it raised it by an inch, I have a 22 inch cooler.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
I'm assuming you don't have your truck yet which is why you are asking?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Lowest point of bed
Lowest point of bed
