Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HLE 2Dr
Well I found out something on the roadtrip I took last week. And I apparently somehow had missed this factoid that a Ford Lightning customer support guy clued me in about (cause I didn't read the manual yet).
I had to make a hasty trip to attend a funeral and hadn't investigated all the "EV trip planning" stuff I was supposed to do beforehand, just threw my stuff in and winged it.
I used a 350Kwh EA charger at my first charge location cause I thought it would speed things up. When I left the truck it was rockin' along at 158Kwh. I returned to the truck about 15 mins after starting the charge to find the rate was like 56Kwh and it never got better. That was a long wait to 80%.
Later during a discussion with the Ford Lightning guy the next day I described what had happened and he said I should stick to chargers that were 150Kwh since that's what both the Lightning and Mach-E are designed to charge at. I felt pretty stoopid. After that I had zero problems and all recharges took around 20 mins (40%-80%).
So while setting up to do my OBCC module update in FDRS yesterday I checked for DTCs and sure enough there was one that was set earlier (but not currently) for the OBCC. I'm sure it was that event with the 350Kwh charger that caused it. I cleared and retested...all green.
So I'll be staying away from the 350's from now on.
