tommolog
New Jersey
www.youtube.com
2022 F-150 Lightning Lariat, 2023 Rivian R1S, 2024 Chevrolet Equinox EV
Journalist
For context Kyle went 10mi AFTER the range meter went to 0mi. @tommolog still had 2mi to go when he stopped so the no kidding range stop would probably be ~280mi.
Not that I would ever take it that far to the edge, its nice that Ford has a little safety buffer in there.
Also... would not be surprised if Ford offered just a little bit more range with an OTA update. Thats what happened with the MME when they became more comfortable with the battery reliability in real world use.
But understand, Kyle pulled off the highway at 250 miles. I drove at 70 mph for 268+ miles. For me, the range test pretty much ends when I can no longer drive at 70 mph (it's a 70 mph range test!). Kyle's final 10-15 miles were done off the highway at lower speeds, and he explains that.
I am certain that I couldn't have driven 10 more miles at 70 mph. So no, it wouldn't have been 280 miles, probably 275 as I explain at the very end of the video. :)
greenne
Nathan
Niskayuna, NY
Very true and I'm not criticizing...love your range tests. I'm not suggesting you repeat Kyle's method of running it completely dry.
I do feel fairly confident that you could drive it pretty darn close to zero on the display and be OK....unlike the Bolt which ran out right at 0 and the polestar which severely limits power below 5%.
It seemed like you had full power almost until the end. How did it behave when you got really close to zero...any power loss?
I've owned many Ford's over the years..they do play it conservative which is in line with the Mach E.
tommolog
New Jersey
www.youtube.com
Journalist
I didn't think you were being critical :)
Yes, there is definitely feel the reduced power once you get under 5%, maybe even a little earlier. I got off the highway right as the SOC hit 0% and drove about 1.5 miles to the EA station at lower speeds.
sotek2345
Engineering Manager
Great video and test. As I was expecting, we get about an extra 30 to 40 minutes of highway driving vs. our Mach-e GT.
gorwell
Sacramento
Ioniq 5 / XLT Standard
@tommolog
While we have you, in one of your charge videos can you give 5 minutes on the Standard range charging and share that theoretical charge curve that I think Ford shared with you at one point :)
Also, if you can squeeze out of Ford why the the max charge on Standard range is lower than Extended, I would love to know that as well :)
tommolog
New Jersey
www.youtube.com
Journalist
@tommolog
I've arranged a loan of a SR Lightning. I'll be doing that recording and analysis soon
Stlww18
St. Louis
2022 Lightning Pro, 6/3 blend date
@tommolog
If I remember correctly it's because the ER battery can take higher power levels without encountering heat issues; bigger battery, bigger heat sink.
Firestop
Firestop
@tommolog , I too really appreciate your work and the info you share with the community.
This forum has been slowly filling up with FCSP use issues now that more owners are Putting them to use. The conversations that concern me the most are potential charging issues that are being hypothetically tied to higher ambient home garage temps (e.g. 95-115) that are now becoming the unfortunate summer norm in many places.
Do you or those in your circle have any thoughts on these concerns?
I’m looking forward to you future vidoes and data!
gorwell
Sacramento
Heat sink wouldn't be a difference between the two..
The standard and extended batteries are in the same enclosure (seen below). Just in the standard, that bump out on top isn't filled with anything. If anything, the standard would have better cooling given less heat caused by the additional batteries :)
Plus if you order Max towing, you have an additional cooling pump that can address heat.
Trying to figure out if Ford gimped it due to some part of the physical build process... or if it's just being extra conservative and software limiting it. Then, can update that curve notably like VW did.
Ford F-150 Lightning F-150 Lightning 70 MPH Range Test by Tom Moloughney = 270 Miles @ 2.1 mi/kwh 1657742016747
Stlww18
St. Louis
Sorry, I meant that the battery effectively acts as a larger heat sink. You can push more power into the bigger battery before it starts overheating. Smaller battery heats quicker.
I agree with you, I expect those with Max tow in ER and SR will someday get an improved charge curve, if heat is the limiting factor.
adoublee
Midwest
2 EVs
@tommolog
I feel like a good OTA update would be for Ford to increase the precision of miles/kWh value to hundredths position. It makes a difference since the battery is so big - not knowing if/how they are rounding, there is a good 5-10 miles of uncertainty locked up there for people who want to base future range on experienced mi/kWh knowing coming real world conditions, versus the GOM miles estimate.
Agree?
@tommolog
Do you plan to to a video on the 80a charger, separate from the home integration? Would love to see you compare it to a ChargePoint Flex or Juicebox with regards to cord, plug and overall quality.
tommolog
New Jersey
www.youtube.com
Journalist
@tommolog
Yeah, I'll do that for sure
So with the ER battery, the Lightning gets the same highway range as my Mach-E ER AWD, but uses 45% more energy.
I may hold off ordering they add another 100 miles to range.
sotek2345
Engineering Manager
You must get much better efficiency than we get in our GT. The Lightning will have 30 to 40 more miles. We only get about 220 - 230 on the highway.
