Why power output limited to 64% ?
piratefan2
Paul
NC
23 Lightning XLT-ER, 24 Silverado, 06 Silverado
Does anyone know why my truck capped the power output to 64%? This happened while driving normally (60 mph, flat roads, 89 degrees).
Ford F-150 Lightning Why power output limited to 64% ? EE5AE126-E662-4E89-9392-9ACFA9A30606
sotek2345
Engineering Manager
Had you recently fast charger? That will heat up the battery and limit power until it cools back down.
Do you have max tow?
bobrosco
Ryan
2022 F-150 Lightning
Battery temp looks good on the gauge though.
piratefan2
Paul
NC
I had charged it on my level 2 charger for less than an hour. I do not have max tow.
sotek2345
Engineering Manager
Coi
Could have been a software fluke, or could have been protecting the battery from heat. Without more data I can't really say. Restrictions like that happen all the time in our Mach-e GT
gorwell
Sacramento
Ioniq 5 / XLT Standard
Unless you can reproduce it, I would write it off as a fluke. Truck probably got confused.
V8BoatBuilder
Aaron
New Jersey
22 Lightning
Did it go away?
Did you try turning the truck off and on again? Not a great solution for a TRUCK, but may help with the troubleshooting.
Blainestang
FL
F56, R55, Pro
Coi
You get power restrictions from charging on L2?
sotek2345
Engineering Manager
Not from L2 specifically, but I'd it is too hot, or too cold, or the battery charge is too low (starts at 70%), or you are driving too fast (over 65) or the moon is blue on a Tuesday. GT is very sensitive.
piratefan2
Paul
NC
Did it go away?
I tried turning it off an and immediately back on. That didn’t help.
After letting it sit for a few hours, it went away.
2000Firehawk
2022 Lightning Lariat ER
Recently had the same issue and same percentage. No fast charging and wasn’t even post-charge, was after coming back to the truck from the store. Went away the next day and hasn’t come back since so I wrote it off unless it showed again.
piratefan2
Paul
NC
Good to know! Thanks!
Blainestang
FL
F56, R55, Pro
Thanks. Hopefully, the Lightning, especially with Max Tow, is less sensitive.
