F150 Lightning FORscan thread
jredondox
Jorge
San Diego, CA
2021 F150
and can we post the lines that need to be edited everytime we find something that works?
vandy1981
vandy1981
Tennessee
Plumber
vandy1981
vandy1981
Tennessee
Plumber
Yes, please post if you find something that works. I'll try to add it to the OP.
tx_lightning
TX
2013 F150, 2022 Lightning XLT XR
I've started playing around with module configuration in our Lariat ER using FORscan and didn't see any dedicated threads for this subject. It would be nice to have a centralized place to share troubleshooting tips. The public version of FORscan doesn't work with BEVs, so you need to email the support team and they may choose to share a BEV-enabled beta version with you. Unsurprisingly, there's a lot of module overlap between the ICE F150 and the Lightning so you can get a good idea of how to enable settings via this thread. I've tried the following setting changes. MAKE SURE YOU BACK UP YOUR ASBUILT DATA BEFORE MAKING CHANGES. SOME CHANGES WILL BE UPLOADED TO THE MOTORCRAFT SERVICES ASBUILT SITE AND YOU WILL NOT BE ABLE TO RECOVER THE ORIGINAL SETTINGS. ALSO BACKUP YOUR FORScan SETTINGS REGULARLY.
Global window open/close using keyfob:
successful, but it only works on the front windows because one-touch is not enabled in the back windows.
DDM740-06-02xxxxxxxx01--
PDM741-06-02xxxxxxxx01--
DDM740-06-0301xxxxxxxx--
PDM741-06-0301xxxxxxxx--
BCM726-11-02xx01xx01xx--
BCM726-22-01xxxxxxxx01--
BCM726-22-02xxxxxxxx01--
APIM7D0-09-01xxxxxExxxx--
Propulsion sound: in progress, so far unsuccessful. I was able to make the button show up on the drive mode page by changing the APIM coding at 7D0-09-05, but it only stays on for a second before switching off. I don't notice any difference in motor sound for the brief moment it stays on. I assume that there is another setting in the ACM that needs to be changed to enable it. I guess it's possible that there is some hardware that is missing in non-Platinum trims but that seems less likely.
APIM7D0-09-05xxCxxxxxxx--
changing 727-01-01 to "xxxx xxxx 0x--" does not enable propulsion sound.​
Glare-free (matrix) headlights (localized dimming of brights based on surrounding traffic): Successful. The necessary hardware is available in my Lariat ER trim. The swiveling (dynamic bending) lights continue to work with these settings. Settings were adapted from this F150gen14 ICE forum thread.
APIM7D0-09-01x1xxxxxxxx--
APIM7D0-09-03xxCxxxxxxx--
IPMA706-01-01xxxxxxx9xx--
SCCM724-04-01xxx4xxxxxx--
HCM734-01-01xxxxxxx0xx--
HCM734-01-02xxxxx2xxxx--
HCM734-11-01073589
Motor/battery numerical temperature: not successful, may not be possible. The ICE trucks let you surface numerical values for the coolant and transmission temperatures and I'm assuming there's something similar for the Lightning.
Changing 720-07-01 to "xxxx xxE5 xx--" or "xxxx xxA5 xx--" doesn't enable numerical temperature display​
Disable double honk with exit of running vehicle:
BCM726-63-02xxx0xxxxxx--
Lincoln Folding Mirrors Setting (folds when locked--only unfolds when ignition started):
DDM740-03-16xxxxxxxx01--
PDM741-03-16xxxxxxxx01--
Disable Seatbelt Reminder:
IPC720-01-01xxxxxx0xxx--
Please post if you've found any other settings that work with the Lightning.
I got the global windows and seat belt reminders to function as well
vandy1981
vandy1981
Tennessee
Plumber
jredondox
Jorge
San Diego, CA
2021 F150
amazing thank you!
livnitup is a friend of mine and is helping me with the lightbar... Want to make it brighter like they did the DLR for ice models
Captain337
Lee
TN
Lightning PRO
I wonder if all trucks have the same sensor package. I’d assume glare free is using the cameras. Do bluecruise trucks have extra cameras or sensors?
greenne
Nathan
Niskayuna, NY
Was able to enable glare-free headlights on my Lightning ER. See OP.
I'm really interested in this feature. Truck is ordered but not built yet. Will check in later this fall.
Snappy22
NJ
Honda Pilot, Honda CRV
I think so--someone posted that the feature was available on a Canadian XLT SR.
Whoa. The pro has vending lights so you think those also might be able to enable this???
jredondox
Jorge
San Diego, CA
2021 F150
Here is the code for bright DRL during the day factory is 10% and reason you can’t see them during the day
first
Bcm
726-42-01 x2x2 xxxx xxxx
Then for brightness
726-38-01 xxxx 64xx xxxx
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
jredondox
Jorge
San Diego, CA
2021 F150
Nice! I didn’t get this one to work. I got the glare free to show up but lost movement o the headlights so I went back to stock
FlasherZ
St. Louis Metro
Is there a good consolidated guide on FORscan usage for the newbies? For example, what must be obvious questions to someone who knows the app - in the "recipe" listed above, do you actually put "x" in place, or do you put the value your truck currently has? And when you save your settings, is it a full save / restore, or does it save only what was changed? etc.
I'm sure I can go hunting for it, but if someone has a great reference handy I'll take it!
