The cheapest, but definitely not the safest
Crilly
Dale
Hartford wi
2 Mache GTpe
The panel
Ford F-150 Lightning The cheapest, but definitely not the safest 1661480459906
Crilly
Crilly
Dale
Hartford wi
2 Mache GTpe
The male, male cord. This is way it is not the safest.
Ford F-150 Lightning The cheapest, but definitely not the safest 1661478561590
Crilly
Crilly
Dale
Hartford wi
2 Mache GTpe
You have to turn off the main breaker on your house electrical panel plus any heavy draw circuits
Make sure truck is off
HOOK up cords from truck to panel
Turn truck on. Turn 30 minute shut down off
I left it hook up for 45 Minutes TV’s, fridges, lights, garage door opener worked great
I did turn the house air conditioner on. The lights went dim while It started up.
I WOULD NOT LIKE TO SEE OR KNOW WHAT WOULD HAPPEN IF SOMEBODY TURNED THE MASTER SWITCH ON WHEN THE TRUCK WAS HOOKED UP EXPRESSLY AFTER THE POWER CAME BACK ON.
Turn truck off. Disconnect the cord. Turn the breakers back on.
Viet658
Viet
Pomona, CA
2018 Tesla Model 3, 2022 Lightning Lariat ER
No issues with bonded neutral doing it this way?
FlasherZ
St. Louis Metro
That's called a "suicide cord" for a reason.
This is VERY unsafe, illegal, and violates code and law.
DO NOT DO THIS UNDER ANY CIRCUMSTANCES.
Use a proper generator interlock and transfer switch (one that switches neutral).
LightningShow
MA
'22 Lariat ER
Product Development
YIKES.
jefro
F150, Corvette, Bolt EV,
We call that a suicide cord.
bizz
NY
Chevy Tahoe, Ford F250
The dangerous part about this is that if you or someone in your house did this and forgot to shut off the main breaker you could kill a lineman working on the lines, that's why you need an interlock or a transfer switch for these types of things.
broncoaz
Cape Cod, MA
The metal interlocks are cheap and effective. I had the electrician install one and a 30 amp generator plug. Unfortunately the bonded neutral issue is causing it to not work at all.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
meanwhile, I’m on my second electrician to not understand this, and so I still haven’t installed my FCSP (I want to knock out both installs at once)
