Backup start passcode
xycarp
SE Michigan
2021 Bronco Sasquatch, Lighting Lariat ER on order
I have setup PAAK and it works fine. I’m trying to set a backup start passcode and it keeps failing with a message to take it in for service.
Is there a trick to it?
Anyone else have this issue?
jpepper07
Joshua
Ohio
2013 Ford F150
I never got my password to set. Even when using a proper password it fails to setup. So I made sure I knew my door code and I took the battery out of my 2nd key fob and placed it in my center console. Then if I lose my phone or it dies I can place the key fob in the cup holder to drive. I also left the battery in the center console if I want to put it back in.
xycarp
SE Michigan
Clever solution. :)
Hopefully someone has actually got it working ok.
O’Majestic1’slightnigF150
Robert
Hondo, Texas
F350 F250 F250 Taurus Cessna Super Air Natique
Retired Engineer & Product Developer
I have had backup code working for about a month. I strumbled on it going thru the settings and followed the instructions. No issues getting it to work and I have tested it accidentally a couple times. Nice feature. The truck knows when you use the door pillar keypad and does not detect you are carrying a fob or your phone with PAAK, asks if you want to use your backup code. Kinda like “dummy, I know what’s going on and I can help you overcome your stupidity”. One of the better thought out, tested, and implemented software developed items.
Do you also have a FOB with you while trying to set the pass code?
Robert
Hondo, Texas
Yes I did. You have to be able to start the truck, or into accessory mode, to get into your settings to program the backup code.
hiimisaac
Isaac
Eastern, NC
F150 Lightning Lariat (510A)
Software Engineer
I had this issue yesterday. I just left the truck for a while. Drove home from work that day and tried again. Worked that time. Idk what it was, but I just figured like most computers if you just let it reset it'd be okay.
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
I revived the PAAK update last night (10/28). Worked perfectly. The backup passcode was set without issue.
STXLariat
2014 Tundra
I can’t get it to work, or reset or delete. I keep getting the following message:
Ford F-150 Lightning Backup start passcode IMG_3187
3121
2022 F150 Lightning Lariat SR Mannequin
Delete the phone as a key profile on the truck. Delete the FordPass app from your phone and start all over. This did it for me
STXLariat
2014 Tundra
Worked like a charm! Thank you for the info.
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
It set up and works for me. It’s a really annoying passcode but it works. I use it when I wash my truck since my phone is connected to the Sonos in the garage. I always just jump in and punch in the code to move it back into the garage after the wash.
Jseis
Washington
I did the door code and start code thing initially with my MME. Then promptly forgot both ?. I’d used the iPhone PAAK for nearly a year with no issues. Then my phone went dead & would not open the car. I jonesd for a lightning (?) cable at the college, charged the phone, went home.
The door code I have now… I’ll never forget. the start code is written down, safely tucked away. . FYI, setting up PAAK is easy but god help you if you miss a step, have wonky Bluetooth, have drunk to much coffee, in a hurry, have 7 digits on each hand, are dyslexic, and have no Millennials or Zers nearby to assist.. ?.
