Where is the charging station etiquette?
AZT9
AZT9
Peoria, AZ
You’re confused because the people writing those articles and rewriting them and stealing from each other to make click bait news app trash are confused. A press release from this or any other WH is also not to be taken too seriously. Neither is any actual quote in 2022 because journalistic integrity died with Dan Rather.
It’s a lot of static to manipulate stock prices and that’s about it. Count on nothing from any of them until it absolutely must happen, and when it does happen count on it to be half-assed and barely functional.
Damn it. Media got me again!
4Reeley
PA
Lariat
What's the etiquette on the line/queue? From my limited experience there's no natural formation of a line, only a car or two parked nearby waiting for the next open station. Do folks arriving at a full station for the most part recognize an informal queue based on order of arrival? Do you wait in an adjacent parking spot or in an aisle ready to jump (this is probably location dependent). Do you engage with the charging folks to try to figure out which spot is freeing up next?
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
This is my question too!
When I drive up to a full set of public DCFC chargers, I sort of see who is waiting for a charger based on the vehicle, but there is no way to know who is next.
Need a pull number tag system !
F150ROD
U.S. Navy Retired
I thought some of these have a way of reserving certain station, I might be wrong
AZT9
AZT9
Peoria, AZ
In my experience with EA chargers, I usually see people collectively create a queue and follow that. I’ve also seen some random ass just happen to pull in as a charger is feeing up and attempt to charge. It typically doesn’t go well for that individual as there’s an instant swarm of people who have been patiently waiting “in line”. Only once did said bad apple pretty much really the line of ppl to “F” off and there wasn’t much that could be done at that point.
metroshot
Pat
Montclair, CA
Networking Tech
ChargePoint and EVgo have a reservation system but I don’t know if all their stations utilize it. EA does not.
EA has a bell system that tells you when a charger opens up.
But nothing like "who is next gets to charge system"
mr.Magoo
2022 Lariat ER, AMB
Fastest way to educate people is through the wallet...
$200 fine if you occupy an EV Charger without being plugged in.
Charge based on time spent... EA already have this some places to an extent...
If you're a 50kw/h guy occupying a 350kh/h charger your rate should also be 3-4 times as high as if you were on a 100kw/h charger (where options are available).
Charge per rate supplied:
100+ kw/h is $0.10, 50kw is $0.30 10kw/h is $0.60
Charge per reached state of charge:
Up to 80% at one rate, 80-90 another and 90-100 is $1 per kw/h
This way you're giving people a financial incentive to move, many times today EV spots are prime parking spots and people plug in wether or not they need it simply because they can. Make it hurt the wallet if they "over stay".
Obviously there's more metrics and massaging required, I'm just outlining the general concept, not saying this is the exact answer...
MRButtler
Matt
2022 Lariat Lightning
A fantasy for a moment: Our 2nd heaviest EV on the market, can pull 7700 lbs right out of an EV spot.
awilli1010
SE Michigan
Here's the problem with your request. You've got the uninformed, you've got the idiots, you've got the a-holes, and then you've got the rest.
While in some areas like California and Arizona, you may find congestion, much of the rest of the country is not experiencing that. Yes, it's changing, and it may get worse before it gets better.
Here's some random cities - note the difference in density of Electrify America chargers:
LA
Denver
Greater NYC
Greater Detroit:
The “Motor City” needs to step up the charger installs!
sotek2345
Engineering Manager
That could potentially cause damage. Parking directly behind them while you wait and blocking them in however...
MRButtler
Matt
Yeah the fantasy ends with real damage you're liable for, random crowd approval not withstanding.
What good is it to block them while they are actively going nowhere anyway?
Guess the social thing to do is shame and report.
SilverBrewer
Beau
Cincinnati, OH
2021 F150 Platinum Powerboost
My issue is unlike Tesla, by me EA and EVGo don't charge idle fees. I think this will be an absolute must.
GoodSam
Good
occupying space
This EA station indicated idle fee would be charged:
Ford F-150 Lightning Where is the charging station etiquette? IMG_20230107_174327552_HDR
I was using the kW-hrs of the Ford initial 250kWhr.
cwstnsko
Mesa, AZ
2023 F150 Lightning Lariat ER
The mechanism is there to charge idle fees on EA, but most stations seem to be set to $0.00 per minute
