Pro Power can’t run a 15 amp saw
JLee
NJ
2022 Lariat ER, 2015 Mustang GT, 2005 GX470
Has anyone else seen this? I tried both 2.4kW circuits in the bed with the same result.
I’ll put a Kill-o-Watt on it and see if it’s under volted, as the saw sounds slow for the few seconds it does work.
Edit: Kill-o-Watt confirmed bed outlet voltage dropping as low as 66.7 volts under load before stabilizing back around 120v. Frunk and interior outlets are fine - no issue with this saw.
I guess you don't also have anything else that is plugged in and pulling power at the same time...
I would also try another tool to see if the same thing occurs...
also, try one of the outlets in the cab, and even in the frunk...
JLee
NJ
Correct, it’s the only thing connected. It works fine on a house outlet or on Flexvolt batteries. I’ll try my tablesaw and see how that fares.
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
The issue is probably the inrush current for the saw. While the saw has a rated current of 15 Amps it *probably* pulls way more than that for a few seconds.
Maybe an electrician on here can help explain it better than I?
I think my wife has the same saw, so maybe I’ll try and rig up a current clamp to measure it…
JLee
NJ
Inrush would be on initial motor startup - it does run for several seconds (I was actually able to complete a 2x6 cut over ~4 cycles), but in any case that's generally an issue for equipment operating on lower power inverters (e.g. a 400 watt device on a 500 watt inverter may exceed 500 watts briefly and trip something), but with 2.4kW available I should have the full equivalent of a 20 amp household outlet.
Nick Gerteis
Nick
Mississippi
Letter carrier
Let Farley know. This would not be acceptable.
JLee
NJ
Massive voltage drop confirmed under load from the bed (66.7 volts). @hturnerfamily good call on frunk/cab outlets - those are fine.
d2blake
Tavistock, Ontario
2010 F150 FX4
Engineer/Contractor
I wonder if that's an issue with your truck wiring? Mine worked fine for miter saw and table saw.
Ford F-150 Lightning Pro Power can’t run a 15 amp saw 20221002_210755
VeganF150
2018 F150 Platinum
Dropped it off at the dealer yesterday morning - now we wait.
I got a Bronco Sport as a loaner.. :sick:
At least you got a loaner. The dealers around me offer no loaner at all
