detansinn
detansinn
United States
Does Sunrun provide the office chair? Are you limited to gray?
If I don’t have Kerosene heater handy, will a propane tank do the trick?
This is the first install example that isn’t an intimidating DIY effort. ?
skyak
F250, 911, Lightning
Self Install.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs BADFA953-CB7A-48EC-839F-757BFB8BE1B2
Ford F-150 Lightning Show me your Ford Charge Station Pro installs 0DA86CB1-28B4-4F92-85CC-57DD80F2A3AA
Tomwilli2025
Alabama
Sales
On a 80amp breaker and FCSP down rated to 64amps.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs PXL_20230415_154355879
swesson
Scott
CO
I picked up my F150 Lightning last week and feel lucky that my Charge Station Pro arrives today. We already have a 40A EVSE that we've been using, shared across our other EVs, but we feel that it's time to add a second -- and an 80A EVSE makes a lot of sense.
I am looking for some photographic inspiration for installing the Charge Station Pro, everything from wall mounted in the garage to concrete and exterior walls. Please share pics of your installs. Thank you in advance for sharing!
Ford F-150 Lightning Show me your Ford Charge Station Pro installs IMG_2759
Jarratt
Jarratt
NM
Tundra. Tacoma, Model 3, Lariat Max Tow, lng range
went through 2' of rammed earth in the utility room and then underground.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs Pro Power Charger
Typoman
Larry
Willcox, Arizona
22 lightning
I called this my Tweety Bird house. I felt that it needed to be shielded from the Sun and the rain
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
8 months long installation.
48A ChargePoint and the 80A Power Pro.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs PXL_20220830_202515980
drummer
Ankeny, IA
2023 Tesla Model S, 2024 Tesla Cyberbeast
After upgrade to 400A service.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs IMG_3369
eettare
Eric
2022 Lightning Platinum
Yes
Built a box with the wires running down through the same pole that it hangs from. Wires run in soffit under deck back into house and main panel where its powered on a 100 amp circuit.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs IMG_1020
Ford F-150 Lightning Show me your Ford Charge Station Pro installs IMG_1019
Biobob
Robert
Chico
2022 Lightning Lariat
I received my charger before my truck last November and had it installed before getting my truck at the end of November.
Ford F-150 Lightning Show me your Ford Charge Station Pro installs IMG_0190
