Departure time disappeared from FordPass app
prvpilot1
James
Mankato Mn
2022 Ford Lightning Platinum
It appears in the latest update, departure time has disappeared from the app. The funny thing is, my truck still does the conditioning without me being able to change or stop the departure times. The other bad part is that if I use departure times, my steering wheel heat doesn't work after that.
Why can't you change the departure time in the truck itself?
prvpilot1
James
Mankato Mn
It no longer shows the option. If you go to charging in the truck, the option for departure time is grayed out.
It looks like you have an update either stuck, or in-process. Give it a day or two and if it still doesn’t work, schedule service.
prvpilot1
James
Mankato Mn
Awesome. Thank you for the info. Hopefully that takes care of it.
That's unusual how it's grayed out on the charging menus!
Are you not seeing Departure Time on the main "VEHICLE" page as shown here?
Ford F-150 Lightning Departure time disappeared from FordPass app 1681843821219
BTW, the temporary loss of heated wheels upon using pre-conditioning is a known and persistent defect, a fix is promised at some point, but a solution around this problem, program you scheduled departure time for 15 or more minutes sooner than you actually intend to use the truck, this extra time allows the systems in the truck to sleep, then when you actually go out to start the truck normally, the wheel will warm up quickly.
GolfJRM
San Diego
2023 Ford Lightning (If it ever gets delivered)
Teacher
I hate the heated steering wheel not working after preconditioning
prvpilot1
James
Mankato Mn
It doesn't. Just shows the vehicle status no alerts.
As mentioned previously, wait a few hours or a day for any truck updates to finalize.
I suspect something is wrong with the Fordpass app, I've noticed a few flaws not related to this discussion as well in version 4.25.0
Try a few other things with the app if the departure time feature is still missing.
Clear the cache, force stop the app, close all apps, then restart the app.
Hopefully that helps, if not, try logging off the app, then logon.
prvpilot1
James
Mankato Mn
looks like I dont have driver characteristics enabled so it wont allow departure times.
Did you make changes to your approvals of the connectivity & data sharing controls in the truck??
prvpilot1
James
Mankato Mn
I did. I didn’t want to send all my driving info to ford. They say that is why. Plus the charging info doesn’t show up because of it.
