derm
- First Name
- Lance
- Mar 3, 2023
- Chesapeake VA
- 2023F-150 Lighting Lariat. 2003 Ultra Classic
I have repurposed my Electric Stove wiring (ALCAN S STABILOY (R) AA-8000 AL TYPE SE_CABLE 600V 2 CDRS 6 AWG) from the Kitchen to the garage to the NEMA 14-50 Outlet. House was built 1997. (Stove was changed to gas)
SPEC's
-The Alum Cable is 6/2 with shielded aluminum ground.
-I Twisted the Ground Shielding to the NEMA 14-50 Ground Terminal
-Phase(A and B) to the (Y1 and Y2) NEMA 14-50 Terminals.
-Swapped the 50 Amp breaker to 40 Amp GFI
Do I need the Pig tail the Nuetral Terminal off the Sheild?
Does the Ford Mobile charger require Nuetral.
- I can't see running a second 6 guage ground wire and it would be a bitch getting to the panel.
- I Can't be the only one that used 6/2. 6/3 is not common.
Thanks for the help.
SPEC's
