tls
Unlikely to find a large breaker rated other than 90C in a modern panel. And a 100A disconnect like the one you pictures is likely to cost about the same as a tiny residential outdoor panel, though with a 100A breaker too it may tip the scale. Either way will work.
The point Isn't to change the conductor size - it's to change the conductor material, if the charger itself is not rated for Al or the large Al conductors are hard to manipulate inside a tight charger enclosure. #3 copper will take 100A and is much more flexible and easier to work with than #2 Al wire - but it costs a lot!
